Henrik_imp
Been there
I just came across this newly released product from Moriwaki. I have never actually heard of such a micron oil filter, and have always used throw-away filters in the past. I was wondering if anybody here is familiar with this, and if indeed it would really add all the benefits that Moriwaki says:
Quote:■ Main features
・ High-performance oil filtration performance
・ Oil flow up to 7 times that of fiber filters ・
Significantly reduces the time required for the bypass to open and circulate, constantly filtering
・ Ideal in a short time immediately after starting the engine Provides
oilpressure・ Reduces the burden on the oil pump, contributes to power and torque increase in the entire area, enables excellent oil flow, improves oil pressure and oil temperature
・ Adsorbs metal even at high temperatures with neodium magnets
・ Filtered impurities Can be easily visually confirmed and the condition of the engine can be grasped.
-High strength with a machined monoblock aluminum body. Cooling performance is improved with a heat sink.
Quality that is trusted by the aircraft industry with FAA / PMA certification
. Can be cleaned with a commercially available parts cleaner and can be used repeatedly. Economical and eco-friendly
It certainly looks great though:
You can find out more here, but you wold need to translate to Englis (unless you are fluent in Japanese that is...) https://shop.moriwaki.co.jp/ec/detail/?product_id=3328
