Meter & headlight buckets
thumper_imp said:
Yes,I have (see headlight removal thread) The biggest problem I had was getting the connector of the bulb,I had to go to the dealer in the end and even their head mechanic had a heck of a time.I think that there was something wrong with the 2 tabs.I put a dose of dielectric grease on it and now it is fine.The meters are a 5 minute job and the headlight bucket is very easy too.Just take of the 2 bolts and wiring clamps inside the shell.There is NO NEED to disconnect all the connectors,just feed them thru the hole in the shell,very easy,about 15 minutes .Hopefully your light bulb will disconnect easier than mine did.
