Larger rear sprocket
beardyweirdy@me.com_imp said:
I've done it both ends. One down on the front and two up on the rear.
With my engin mods making just shy of 100bhp it could pull more but I like to be able to use all the engine has. I can rev it out in 4th and still keep my licence... just!
I find 5k rpm + a great and harmonious place to be and usually keep the engine moving.
If I went back a tooth or so then I'd probably be able to get a few more tenths of a second on my 1/4 mile times, but it feels great and that's what it's all about for me.
6th still feels like an overdrive to me but now pulls more keenly when I do need to zip past something.
I like your idea, just to reconfirm:
Do you have the part number for the front pinion & rear sprocket is 206909.
Do you need to replace the original chain?
Will that fit a 2017?
Thanks
Sorry, don't have the front gear part number.
The 42 tooth rear sproket works with the stock chain.
According to JT's chart the 2017 uses the same sproket.
chync_imp said:
I think it’s just a nylon insert in the nut to provide friction isn’t it?
They look like metal clips of some type. They are intregal parts of the nuts.
Should be just fine right? The speed sensor reads the pulser ring on the rear wheel.
Thanks guys. I’m going to order one too. Need a new rear tire soon and this will be a good time to replace the sprocket.
You’re going to need an impact tool to get the sprocket nuts off. If you don’t have one, loosen them while the wheel is on the ground and have someone hold the brake. They are on tight!
Thanks
Thanks
Hi Alain,
I'm sorry I don't have any part no's but can tell you that it fits without having to alter the drive chain.
I think someone else answered the 2017 question...
Installed
Retsel_imp said:
Alain, here is the front sprocket from Sunstar.
HONDA CB1100 (13-19) JT Brand Steel Sprockets & 530 Chain Kit
I was out on the freeway yesterday and found that I am now, with 42 tooth rear sprocket, turning 3500 rpm at 70 mph in 6th. 65, my crusing speed, was at 3200 rpm. Works for me!
Using the chart provided by PD, it is pretty close at 3401 for a 70 mph speed. With the 42 tooth.
Thanks will get both (Fr & Rr) in a few days
Can any one can confirm the number of tooth for the Drive front sprocket.
I already got the part number for the rear sprocket for 42 tooth..
Bike is a 2017 CB1100
Thanks.
