Headlight Modulator On a 2017 EX?
Paris_imp
Running like a top
Has anyone installed a headlight modulator on a 2017 EX? The LED headlight seems to be a proprietary multi-LED unit. I’m looking at the wiring diagram and there appear to be two possible + wires for the low beams, one H/L low (BAT in), and the other PO/L (BAT in). I’m not sure which one I would tap the modulator into. Of course, I’d love to find a plug and play unit instead.
cessnet_imp said:
how did it go? find plug n play?:beerchug:
I might have found one. After a lot of digging, it turns out that the 2017 Honda CB1100 EX LED headlight module is made by Stanley, and may or may not be similar to Stanley units used in Yamahas. The engineer at Kisan is going to check for me. In the meantime, I need to see if my Honda has a 4 pin plug for the headlight. If the stars align right for me, I could then use a Yamaha plug and play from Kisan. If not, then I could use a Kisan Pathblazer P115W-H3 splice in unit, which I would need to specify at purchase as being programmed for LEDs.
The engineer at Kisan gave me some good advice. I would have spliced the modulator to the low beams, but he suggested it was better to modulate the high beams. That way, I can turn the modulator off during the day anytime I want just by switching off the high beams.
