Has anybody installed flasher relay for led signals?
Romo1969_imp
Running like a top
I actually bought one that is specified for honda. Figured there would be a spare unused plug that was obvious. Not so much. Anybody know where to plug this thing?
A power source? There is an accessory plug by the battery and one in the headlight shell.
Are these on the pre 2014 machine and if so where are they. Are they coloured; is the information in the manual?
Those flashers are designed to replace the existing flasher unit, not to be used as an "add on".
They are colored. But at the moment I can't remember what color and am not near the service manual. If you remove the headlight you will see the connector as it is the only unused one in there. The battery one is the same.
If no one chimes in, I'll look after work. And yes, pre-'13 model. I would expect the '14 to be the same, but I haven't seen a '14 service manual.
Just so you know, I'm only posting about the accessory connectors. Sounds like RandyB knows about the flasher relay question.
Anyway, the connectors are red and should be capped. They have a green ground wire and a black/brown 12v wire. As always, you should verify with a multimeter as just because its on the internet, doesn't mean its true ;)
Randy
Do you know where that flasher unit is?
