Givi Side Case Racks...Do they exist?
cbolling_imp
First service completed
I am thinking about picking up a CB1100. I just sold my BMW RT and don't want to live without side cases. I had a pair of Givi E21's on a previous Kawasaki Versys and they would be perfect on the CB1100. Does Givi make racks for a 2013 or 2014?
Join date 2-24 2014..1st post 7-17-2020 :huh:
Lol well the forum does better when the form members actually participate occasionally
Cbolling, if you want to stick with Givi, they do make a top case rack. You could get a rear rack and case and sell your side cases to get some of your money back.
Sometimes a man just has to ruminate on an idea for a while. Glad to have you on here, Cbolling! Redbird has sweet Givis on his bike so I'd listen to him.
look into the sw motech EVO side carrier / rack:
link:
https://sw-motech.us/bike/HONDA/CB1...ge/side+carrier/EVO+carrier/4052572023365.htm
those side racks have pre punched holes to bolt on the givi monokey mounts:
Link:
https://sw-motech.us/bike/HONDA/CB1.../luggage/side+cases/adapter/4052572007853.htm
here you can see those Givi monokey hardware parts (triangle clamp on top bar, two mushroom pegs at bottom, 4 rubber bumpers on sides ) fastened to the EVO racks:
i have the EVO racks on my cb1100 , with the givi hardware per above, i have mounted a set of givi e22 (same as e21, different lid) on my bike.
I have these SW Motech EVO side carrier/rack and made total of 70 Kms = NO complaints, excellent !
Thanks, for the replies and sorry for not posting sooner. Yes, I have been a member for a long time but have never really posted. I bought a 2014 over the weekend so I will be an active member going forward.
I looked on SW Motech's web site and the rack are not available. I will have to check some of the other links. Hopefully I can find a set for sale somewhere.
Here is my bike by the way.
peterbaron_imp said:
Did you check SW Motech - Germany or Twisted Throttle/USA or Canada...eBay???
I checked Twisted Throttle a few weeks ago but now that I have an actual item # to search for I may have better luck
Trapezoid shape side racks are more universal, the biggest issue might be with the hardware for your '14 CB...it also fits '13 model. I did transfer from the '13 onto the '14 = no issue.
May this help you more/better?:
For these ^^ side racks, I use pictured bellow AERO side panniers , also by SW Motech:
And this is how they look on my bike
Make sure you get the side racks with hardware matching your side panniers...otherwise may not work together.
There might be some other options by SW-Motech or different companies. Check.
Good luck!!
I found some SW Motech racks on Amazon. Price seems to be way jacked up though. I guess I will have to relocate my rear blinkers. Has anyone done that?
First pic below is a U shape bracket with 6 holes, OEM SW-Motech.
You can easily make it by urself from a nice piece of metal strap, shape it, fold it and drill 6 holes of different diameter: 2 bottom for the U shape bracket holding bolts, 2+2 wing side L+R to accommodate the turn signals. If you chose this design, you'll have to make one side turn signal's harness longer by about 1 foot, and I believe is the R-side, as the turn signals harness runs on the L side of rear fender, then you have to drill a hole below the stop light - in lamp's black housing to run the turn signal wires through it.
Here are some orientation pics:
This is what I did with my OEM SW Motech.
You may go alternate way and see if lic plate bracket + home made extension can accommodate relocated turn signals + both T-signals harness extension by 1-2 feet
