the Ferret
:rofl: yea...he's kidding folks, don't anybody do that
Yes, that's why when you're more hard on brakes the extra force minimize the vibration. Grease suppresses the vibration and there is no noise. Until Honda or their supplier come up with a new compound combination.VLJ_imp said:Acrobat, ABS sensors don't measure anything that has to do with the brake pad compound, so switching to aftermarket pads should have no effect on the ABS system. I changed pad compounds on my ABS-equipped XSR900, to no ill effect.
So, from what you're saying, the only remedy they've tried that worked (other than swapping pads) was adding grease to the back of the pads?
The ABS was tuned under a certain conditions, which are usualy diferent to what we find in real use.Acrobat_imp said:Yes, that's why when you're more hard on brakes the extra force minimize the vibration. Grease suppresses the vibration and there is no noise. Until Honda or their supplier come up with a new compound combination.VLJ_imp said:Acrobat, ABS sensors don't measure anything that has to do with the brake pad compound, so switching to aftermarket pads should have no effect on the ABS system. I changed pad compounds on my ABS-equipped XSR900, to no ill effect.
Of course this is also not a very elegant engineering solution like Triumph's ridiculous rubber patch.
You are right also about ABS sensors, but the job of ABS is to use this measurement to modulate breaking as long as you apply pressure on the lever after detecting locking. And friction characteristics plays a major role to the performance of the ABS.
The devil is in the details...![]()
That was one of the things the dealer suggested to me. But they did not touch the front brakes when replacing the rear disk and pads under warranty.Aussieflyer_imp said:You could try taking the sharp edge off the pad friction material. Run a file at 45 degrees around the pad to round off the sharp corner. This may help to reduce the chance of vibration, it's worked for me in the past ... no guarantees.
Take up drinking as a second hobby !VLJ_imp said:Perfection is a real problem. I realize this now, with this bike. The cosmetics are so gorgeous that I lose my mind the second I spot a speck of grease on a wheel, a scuff mark where my knees contact the side of the tank, a swirl pattern or slight haze on the tank, polish lines in the instrument display, etc.
I was similarly anal about my first VFR. I haven't been that anal about any other bike, until now, with this CB1100.
I really need to knock it off, before I drive myself crazy and/or stop enjoying the bike.
I have had the same issue with my 2017 EX and plan to bevel the pad edges and add some grease to interface between the pads and pistons. I'll reply back once I know if it solves my problem.VLJ_imp said:Brought the bike back to the dealer today. Sunny day, so they were able to ride the bike and do their thing.
First off, the Service Manager called Honda to see whether they would authorize a warranty job for squealing brakes. Apparently the answer was yes, because he went ahead with the job. I told him what people here have been advising, i.e., apply brake grease behind the pads, and file off the edges of the pads.
Those two things are exactly what Honda recommended to his service tech, and that's what the guy did.
When the job was finished, I took her out for a quick hundred-mile spin in the foothills. There was one instance when I thought I might have heard some slight squealing, so I removed my earplugs and rode the rest of the way without them. I'm not sure, but there was one additional time when I thought I might have heard a tiny bit of squeal, but it was iffy. It may have been the cars in front of and beside me. Otherwise, there were many other slow, gradual stops that were completely silent. I tried like crazy to make them squeal, and even without earplugs they passed all my usual tests.
So, either it's 100% fixed, or very close to 100%. Hopefully this proves to be a permanent solution.
I understand that they are an ALOC bolt with blue Loctite pre-applied.Bobcat_imp said:I have had the same issue with my 2017 EX and plan to bevel the pad edges and add some grease to interface between the pads and pistons. I'll reply back once I know if it solves my problem.VLJ_imp said:Brought the bike back to the dealer today. Sunny day, so they were able to ride the bike and do their thing.
Just a note for anyone who might be planning to perform the same procedure: the factory service manual states that the caliper mounting bolts need to be replaced rather than reused. I assume that means they are a torque-to-yield type of bolt. The part number for the bolt is 90131-MGC-000.
Is crazy really such a negative thing?!VLJ_imp said:Perfection is a real problem. I realize this now, with this bike. The cosmetics are so gorgeous that I lose my mind the second I spot a speck of grease on a wheel, a scuff mark where my knees contact the side of the tank, a swirl pattern or slight haze on the tank, polish lines in the instrument display, etc.
Interesting...mine w/out doing anything hasn't happened for several rides now. Maybe I'm subconsciously controlling for it by braking more firmly. When your acts up, can you make it happen every time you come to a stop, or is it sporadic?VLJ_imp said:The squeal had been completely absent for a decent while now, but a bit of squeal returned yesterday.
Sigh.
