Exhaust Discoloration Question
memphismike_imp
If you change out your exhaust to an aftermarket Chrome Exhaust and/or Slip On, will you still get the Discoloration(bronzing) like on the stock exhausts? Also...If you go with a "Black" exhaust", will the discoloration eventually show thru the Black as well? Thanks gang!
Mike, I suspect the answer is that it will depend on what the aftermarket product is made of. I've got almost black headers now and their are golden patches here and there on the muffler—particularly where it joins the collector or whatever it is. As I recall, the standard bikes have a stainless steel header; the DLX has a double-walled chrome headers which resist discoloration.
I've just accepted the discolouratation as a design feature. Others loathe it.
Yes in my short time of 7 weeks owning it, I have accepted that as well. It would tear me up tho to add a nice Pretty chrome exhaust and 500 miles later start bronzing on me!!!!
The bronzing is a characteristic of stainless steel under the high exhaust temps. The reason the deluxe exhaust does not discolor is because the used stainless steel main pipes wrapped with a second chrome pipe. This keeps the temperature down on the second pipe.
I have a theory. I think Honda went with the single wall stainless pipes on the original model as a nod to the past. As I recall, one of the first mods everyone made to their inline 4 UJMs was to swap out the chrome 4 into 2 pipes for a 4 into 1 stainless pipe from Kerker, MAC, Yosh, etc...
I was not one of those guys and always preferred to keep the double walled chrome pipes, but I was definitely in the minority.
Personally, I like the chrome 4 into 2 pipes fitted to the EX/DLX models best. That's more like what my bikes looked like back in the 80s.
^^^ Interesting theory, Flyn. I agree with you about the EX/DLX pipes, although if Honda had fitted the bike with something like the Pipemasters or Wyvern 4 into 4 pipes, I would have liked it even better.
Mike,
All un-coated stainless single wall headers will turn bronze after several heat cycles. Single wall chrome headers will rainbow color near the engine where temps are highest. Double wall chrome headers like the Delux has will not discolor as the outer wall does not get hot enough. Single wall stainless headers can be Jet-Hot coated with a chrome or colored finish that will not discolor even under very high temps. Cost is under $200 plus your time to remove and ship your header to them. Here is my Jet Hot coated header which still looks perfect after a year on my bike. Cheers.
Chip
Mike,
Chip
Mike,
Chip
[url=http://s288.photobucket.com/user/chipbeck/media/Mod%20a14.jpg.html]
Wow. That looks incredible!!!! Thank you for that info Chip.
Hi Chip,
Do you have to send them a new, unused header or can they coat one that has already been run?
that
Mike,
Chip
Mike,
Chip
Shinchan_imp said:
Hi Chip,
that
Mike,
Chip
Mike,
Chip
Shinchan,
Send them your existing header. My header was a couple years old when I had it coated. I'm so happy with this mod. That bronze header bugged me from day one. The bike looks so much better now. I hand fabricated the shield that covers the collector and catalytic converter and posted about it in the Forum's "How To" section.
Chip
Chip,
I visited the Jet-Hot coating website and completed a form online for seeking a quote:
A few questions to you so that it can help the forum members in the future:
Q1. Per this link Ceramic Header & Car Part Coating in Custom Colors | Jet-Hot — Jet-Hot did you request 0100 POLISHED as the specific coating? Q2. Jet-Hot says "You will need to remove any chrome on your parts. We cannot remove or apply coatings over chrome" . How did you address this on your exhaust headers? Q3. Per this link http://www.jet-hot.com/project-estimate there is a question about "What coating are you interested in?" and there are there some options Extreme 1300 / Extreme 2000 /Extreme 2500 / Please advise/ What did you select for your header? Q4. How did you ensure that the inside of the headers are not coated to avoid damaging the CAT?
Thanks..
--Yes, 0100 polished
--There is no chrome on the 4 into 1 CB1100 header.
--I believe there is only one temperature option for the 0100 polished finish.
--Tell them the header is to be coated only on the outside to prevent damage to the catalytic converter and they will put rubber stoppers in all 5 openings. Jet Hot is familiar with this.
Chip
Chip
Thanks a lot Chip..
Elipten_imp said:
I think we should ask about a group rate.
That would be bad for the forum mileage post.
