drop in mpg
pdedse
Staff member
I've never gotten over 50mpg, the norm for me is around 45.
Of late, with no significant changes other than weather, it seems I'm getting 38-39.  I don't check that often, I just do a quick mental calculation while filling and if it's above 43 I don't think much about it.  What are some reasons for a noticeable difference?  I keep the tires inflated at 36/42.  The valves were checked once at 14k miles, in spec, at which time the spark plugs were replaced.  Currently it has 31k.  Starting is normal.  I don't detect any drag on brakes.  Thoughts?
Pdedse, my remarks are based more on my experiences with Porsche cars than motorcycles, but there may be some crossover. In instances where I saw a significant drop in mileage, causes were traced back to
Dirty oil
Clutch performance
Spark plugs
Vacuum leaks
Brake pads
Tire pressure
Tire wear
Sound like you have already discounted a few items on my list. I am sure our friends on the Forum can be of more assistance than me. David
I've no idea why, but someone I know changed their fuel pump and found their mileage improved.
Gone in 60 said:
Did you change gas source by any chance?
I don't fill up at the same station each time, so yes.  I think it's been high 30s for several tanks of gas.  I'll keep my eye on it and be a more precise to see if it's fluctuating or stays.
Can lower mpg be a sign of tightening valves?
Have you put it up on the centre stand and ruled out any mechanical issues with the wheel bearings, brake pads/calipers, drive chain (links getting stiff)?
I did change out my brake pads around Christmas time, so that's a good reminder to check for drag; drive chain is at 31k miles.  Wheel bearings...not sure about a check for that.
Thanks.
I think the only check for wheel bearings is side to side or up and down play. Or if the hub is excessively warm after a ride
I never thought that using a different brand of gasoline would make a difference in fuel mileage, but after reading a comment above it got me thinking. I have kept a record of my fuel mileage since day 1 with this bike, and I now have over 40,000 miles. I noticed my fuel mileage had increased by about 7%, but thought that maybe this was because the engine had fully broken in. I used to buy fuel at whatever name-brand station was convenient, but I have been using Chevron fuel exclusively for the past three years, and now I see that my increased fuel mileage may have something to do with the fuel brand, or maybe this is just a coincidence? Your thoughts?
I only use Chevron gas and have averaged 50 MPG. It does make a difference because of the detergent additives and other aspects of the refining process. The storage tanks and maintenance practices of the station matter, too.
Here is a video that i believe is fairly accurate:
