calamarichris_imp
Everything designed by the hand of man has its advantages and disadvantages. As PeeWee Herman says, "Everyone I know in life has a big but(t)...":
~Harleys sound great and you never have to adjust the valves, BUT they're slow, inefficient, and the rear cylinder does not get as much cooling air as the front. (That, and you have to ride everywhere with a serious scowl of determination on your face, as if you are on your way to commit your third-strike felony.)
~Crotch-rockets are light & fast, but the cylinders are bored into the top half of the crankcase (disposabike) and being stuck behind an RV on a twisty road sucks even worse when you're on one of them.
~Vertical Twins (one piston goes up while the other goes down) can rev higher and are generally more efficient overall, but they get lumpy and weak at low rpm.
~Parallel twins (both pistons rise & fall together) are terrific at lower rpm and have a sweet, balanced sound, but they create a pressure maelstrom in the crankcase which inhibits higher rpm power.
So what are some of the advantages and disadvantages of the CB11's engine? Not interested in the smile-on-your-face while riding on a sunny day advantages. Every design has its disadvantages, what are the CB11's?
Heavy weight?
Plastic bits?
Throttle governor?
Less cooling air for #2 & 3 cylinders? (Are they jetted identically with #1 & 4, or richer/cooler?)
Heavy weight?
Plastic bits?
Throttle governor?
It's right there.
