Best magnetic tank bag
Welcome to the Forum Cqrlm911. Congratulations on the ownership of a CB1100. There will be no doubt some experiences you will share I am sure. In regards to magnetic tank bags, I personally got away from using them. I think they are great from a practical standpoint, but in the end found it wearing on the tank enamel no matter what care was taken. I haven't used them for over 10 years. Maybe the product offerings are better today and Forum members will ring in on their perspectives. Above all, when not elsewhere, you will be here.
Welcome Cqrm911!!
Can’t help with the tank bag as I use a top box on a tail rack, but plenty of members use them. Hopefully they will chime in.
Welcome Cqrm911. I personally do not care for tank bags, mainly due to the inevitable wear and tear on the tank finish. I have included a link to a video showing some accessories Twisted Throttle added to a CB1100EX. If I were ever to consider a tank bag, it would probably be something like the tank ring mount SW Motech bag shown in the video. There is also an SW Motech bag shown in the video, strapped onto the back half of the seat that is impressive. The only change I would make with it would be attaching the rear strap to the grab bar, instead of to the tail light housing as they have done. This because the tail light housing is chromed plastic.
Some members have added rear luggage racks to mount hard boxes or soft bags. It is all largely what the individual likes, and what will suit the need. Unless I am doing something that keeps me out overnight, or several overnights, I like a small to medium streamlined back pack. https://www.twistedthrottle.com/shop-by-bike/honda/cb1100-ex-2017
Long term use of any magnetic tank bag will cause some finish imperfections however slight. We have an extensive thread somewhere on film patterns to use to cut film for the tanks to use under tanks bags, magnetic or not. I don't use any however.
I have two magnetic tank bags. A large expandable Nelson Rigg and a medium sized, non-expandable Tour Master. I like both of them equally but obviously use them based on what room I need. Both are very well made and come with rain covers.
The Nelson Rigg in side profile. Astute Aussies and Kiwi members will recognize the Ned Kelly pin on the bag. The NR has the less secure mounting of the two because the magnets are on top of the tank vs. down the side like on the TM. It has always ridden behind a windscreen and I've never worried about it coming off. You can place a security strap around the frame in the front if you feel the need for it. I believe some of the piping and trim is hi vis reflective at night. The bag expands significantly if you need extra room should you unzip the bottom compartment to expand it. At that point I might use the security strap depending on how much weight the bag holds:
Top has two clear pockets for GPS or Phone or whatever gadget you want visibility of. They're non-removable but the one in the front tilts:
Top with exterior pocket tilted, You can see one of the exterior side pockets (one on each side) I use them to store maps in:
Inside. It has one mesh pocket on the right side to store things you don't want to be searching for if the bag is full of stuff:
The Tourmaster from the side has a much lower profile and is non-expandable. It too has two exterior side pockets. Note that the magnets are in the side flaps extending down the tank. VERY secure!:
Interior is nicely appointed. Especially the inside of the lid as it has smaller pockets for pens. glasses and so forth:
The TM has a huge removable map pocket so you can sit in a café and review your route:
With map pocket removed. Utah sun is brutal on everything.:
I also have matching soft panniers for the TM. Same build quality although the rain covers have the inside lining peeling off (probably due to Utah summer heat). I run the straps under the seat and they have a number of adjustments and easily removable mounting points.
The Nelson Rigg doesn't have a dedicated pocket for its rain cover so you carry it inside the main compartment. Not a problem because it's cavernous. The TM has a dedicated pocket for it up front. Nice touch:
Also: the Tour Master has a built in carrying handle and the Nelson Rigg boasts ports for a hydration tube and exterior clip to hold the hose, or electrical cords.
I guess if one wants to spend the bucks one could get a Bagster tank cover and bag for that.
put one on an HD and there won't be any finish left probably
oh, and sorry, but I can't help but comment on the Dunlop decal with michelins and sport demons !!!
I run 2 different ones, a small Tourmaster for around town running/day trips
and a larger Tourmaster with matching soft bags (like Frulk's) and small Cortech tail pack for trips
I stopped into my local multi-brand dealer on the way home a few weeks ago to grab some chain lube. Perusing their used section, they had a '14 CB1000 black. It only had 1200 miles, but judging from the fittings, it had probably been ridden hard stored outdoors for at least part of its short life. The tank finish was also badly hazed from the obvious use of a tank bag - very noticeable on the black finish. They were asking $8k for it - very surprising to me that they didn't go to the effort to take some polishing compound to that tank. Fifteen minutes of work would have brought it back to perfect.
But I'm not a motorcycle salesman. I am, however an anal-retentive weirdo, a detailer, and hate any kind of paint imperfections. As clean as my bike was when I got it, I did find a few fine scratches on my tank. I was able to rub them out with no problems, and found the paint to be pretty soft compared to other bike brands I've owned. Easily susceptible to scratches, but they're as easy to buff out if not deep.
Coincidentally, my office is next door to Nelson Rigg's headquarters, and, being the only guy in the parking lot with a motorcycle, they've become good friends. Due to the stuff I haul back and forth to work, my large Givi trunk was transferred from my BMW to the CB. But, on my Bonneville, I have one of their expandable Commuter model tail bags. It takes up the rear portion of the seat, and I have the straps running under it, and zip-tied together to keep it secure and in one place. Nothing touches the paint, and I've got expandable storage that can hold anything short of a lap top.
Cqrlm911_imp said:
Proud new owner of cb1100ex! Any opinions on small or medium tank bags? Thanks
I don't use a tank bag often, but I recently purchased the Cortech 2.0 and have been very happy with it so far. The magnets are very strong and the material on the bottom of the bag seems adequate enough to avoid any scratching. We'll see.
I also like having the removable map pocket on the top. It doubles as an holder for my interstate iPass.
Motorcycle Tank Bags - RevZilla
That's a nice bag deltamark. Just be sure and lift the magnets and don't drag them off the tank, and if you do remove it, wipe the bottom and magnets off before re-installation.
Excellent suggestion, Ferret! Thanks.
