2017EX_imp
Does anyone know how to fix the gap between the rubber grip, and the bar end weight? It is a brand new 2017 CB1100EX! I saw it when I picked up the bike, and figured if the dealer was willing to let it out the door like that, chances were good that I could do a better job of fixing it the right way without screwing anything up than they could ( sad ). I also do not believe Honda would approve of something so obviously sloppy from the factory. There is a groove machined into each weight that starts the smaller diameter of the weight. I would like only that groove to show between the weight and the rubber grip ( slightly less than 1/16th ). On the clutch side the extra showing between that groove and the grip is almost 5/16ths of an inch, and on the throttle side that extra gap is 1/16th of an inch. The switch housings on both sides are spot on, lining up with the locator dimple in the handlebar, and consequently the rubber grips are positioned correctly. Looking at shop manual diagram, the inner handle bar weight with locating clips that the external weights screw into, there is aparantly no adjustment to pull the weights in closer to the grips. Or did I miss something? At the moment, all I can think of is to have the appropriate amount of extra machined off each weight. There has got to be a better way, I would think! Pictures of each side attached. Any ideas?
