auxiliary 12v in headlight shell
Maturecheese_imp
This has been covered on this forum elsewhere so I'm not looking for advice on how to do it just where I can get the other half of this connector in the UK. I'll paste and copy my FB post to save typing it out again
see here
2017 CB1100EX Accessory Plugs
Going to fit a USB charger to my bike but what a palaver. I want to use the 12v ignition circuit supply in the headlight rather than run it to the battery but Honda do not supply a live plug to their blanking auxiliary 12v supply in the headlight casing. Oh no they expect you to but a £137 kit, yes really!
Obviously i can just buy a waterproof plug for £2 odd from amazon but it means cutting the current half a plug off and fitting a new one with around an inch of cable to play with in an awkward place. I will probably have to pull the loom out of the headlight shell to fit the new plug.
In the old days I would have just cut the plug off and twisted the wires together :)
I got switched 12v inside my headlight to run LED lights and didn’t buy anything to do it. Would have been a few years ago so can’t remember exactly how, but I did…
Maturecheese_imp said:
1973cb750_imp said:
Thank you would this one work it was at the bottom on the link you put up, I believe it will
https://www.ebay.co.uk/itm/18449791..._CLK|clp%​3A2047675&epid=6041873059
Should work I believe
I will try to look later. Lord Popgun has previously identified the connector and where to get it.
UPDATE: Townie was the man, Wiring a gps
