torque spec question (2015 CB1100 DELUXE/ABS)
YHK_imp
First service completed
hello everyone!
I bought CB1100 DLX last week.
but it was japan ver. (they called 'CB1100EX special ver'.)
I read the owner manual.
but the japan manual did not have a torque spec.
does the torque spec of CB1100EX and CB1100 DLX are same?
(what I want to know is the front axle, brake caliper mount bolt, rear axle...)
Sorry YHK I thought I had responded to this. I think the other specs are same as the 13 model and I can look them up for you if you still need them (front axle, brake calipe bolts )
thanks to reply, Mr. ferret.
I want to know front axle, brake caliper and handlebar mount bolt(x4) torque value.
:thanks:
Brake caliper bolts 23 ft lbs
Front axle bolt 44 ft lbs
Front axle pinch bolts 19 ft lbs
Handlebar clamp bolts 15 ft lbs
Welcome sir. Need any more, just ask.
Mr ferret,
I need your help!
I bought Over racing SS slip on exhaust.
but it necessary to replace the center stand mainshaft.
I want to know center stand mainshaft torque value.
and exhaust strap band bolt torque, fuel tank mount bolt torque value too.
I have the 2013 manual, but the specs should be the same for that info.
tank bolt. No spec listed. Manual says tighten bolt securely. If you are a torque fanatic, you would use the standard torque value listed for the bolt size. Need to know the size of the bolt.
Center stand bolt. Is Center Stand pivot pipe mounting bolt: 9 ft. lbs. Is an ALOC bolt, replace with new one.
Muffler band bolt: 15 ft. lbs
If you want the general spec for the tank bolt, let me know what size it is. I'm too lazy right now to go look.
Probably 10mm or 12mm
I need to tank lift when I install the 12v power outlet.
Sooner or later when I do that work, I'll re post.
thanks to your response.
