1st gear CLACK
My 14 std does it too. Sounds like it is hurting something but folks seam to think its fine. I'll go with that just to ease my mind.
One thing I started doing if I know I wont be sitting long is shifting into 1st just when I get under 10mph out of second gear coming to a stop or whatever. It doesn't clunk or clank or any of that noise when I do that.. Just something to try.
JustPassinThru_imp said:
veech_imp said:
If you think the clack/thunk is bad on the CB, try riding a Harley...feels like someone hit the motor with a sledge hammer shifting into first.
That's interesting. That Harley trail-of-oil-tears...the H-D guys think it's their needy pets marking their territories.
In fact it's cracked crankcases! :clap:
LOL, that's good-I never heard the trail of tears analogy. I can tell you that after 25 years of exclusively Harleys, I don't miss them even one bit. The CB is KING! :biker:
My wet-clutch TW200 goes in fine.
But I've discussed the Honda clutch with two techs at two Honda bike agencies, and they all agree - mine is normal; and I'm guessing it sounds just like yours.
I don't take it out of gear at lights. If it's a long light, as many near my home are...I kill the engine. Only rarely do I put it in gear with the engine running. If I start it up cold in neutral, I'll kill it to put it in gear and restart it.
I may eventually have to buy a starter - but that's probably cheaper than a transmission rebuild.
Yeah...ummm...don't anyone think that a) it's a good idea to shut off your bike at long lights or b) that starting your bike in gear in any way saves your transmission.
The thunk (aka clack, aka clunk) is normal and is not harming your engine or transmission at all.
It may be; but the force and the jump, show something intense is happening in the gearbox and driveline.
I don't know why shutting the engine down and then restarting it would be harmful. Engine is warm; oil has been up. Those lights near home are LONG - a couple over five minutes, sometimes, to cycle. No, not a dead sensor - an idiot traffic engineer who wants to discourage people from driving; driving ANYTHING. ANYWHERE.
Shutting the engine down and then restarting it, prevents overheating or "over-warming" from long stationary idling. It's not the same as a dry-start, COLD, with no oil on the top of the engine.
I'm sure the starter wear will add up. So be it....
I don't really care much if you or anyone else chooses to start their bike in gear or in neutral; I just didn't want anyone who was reading the thread to think that doing it one way or another was anything more than personal preference. Your bike will be just fine either way.
I also don't care much if you or anyone else chooses to shut their bike down at a long stoplight; I just didn't want anyone who was reading the thread to think that it's a good idea to trade a nebulous theory that they are saving their engine for the very real risk that they will not be able to move quickly enough to avoid being run over. Again, it's a matter of personal preference, but your bike will be fine if you leave it running.
Personally, I like to shut off my bike when right in the middle of a high speed turn as I'm passing a semi on a two lane freeway...makes me feel alive. :D
I think I saw you shut it off when you were riding through the ravines on our ride. At least I THINK that was what happened because you were going really slow. :rofl:
JK, of course. :)
All the clunk is is the gearbox and drive train losing all its combined slack when first gear is engaged. Because of the wet clutch, the drag on the plates from the oil ensures our clutch is never truely 100% released. On cable clutches you could just adjust it tighter so that it released the plates more when you pulled in, but not so much on our hydraulic system.
Bleeding the clutch can help a bit (assuming there has been enough time for small amounts of air to get in) setting the adjustable levers to their farthest position can also give you a tiny bit more pull, but otherwise it's unavoidable.
It's not like our bikes (or any bikes for that matter) make enough power at idle to beat on the drive train that hard anyway.
+1 If you watch the chain while shifting from neutral to first, you can see this in action.
I've had a similar 1st gear "clunk" on every chain drive bike I've owned. My CB750 is actually a bit clunkier than the CB11.
I recall this question popping up routinely over on the old Nighthawk forum. Mostly from folks that were used to shaft drive bikes that had a lot less slack in the drive train.
Uh...okay.
Speaking logically, I think the very-real potential for overheating an air-cooled four with no fan or forced airflow, is a greater concern than the hypothetical that something is going to happen at the rear of the twelve-car line behind me that will make me, again hypothetically, figure correctly it's safer to bust the read and dive in front of that TOWN PUMP double-trailer gasoline tanker that's bearing down on the intersection with the green.
All hypothetical, of course. In a calm moment, I can figure that if the guy twelve cars back gets rear-ended at 20 mph; he'll hit the car ahead, which wil hit the car ahead and the car ahead. Still leaving me with a six-car cushion.
Peace...:beerchug: Out.
Sorry...again you're free to do what you choose, but I wouldn't want someone reading this thread to think that shutting your bike off at a stop light is safer than letting it idle, in gear. Also, how'd those twelve cars get lined up behind you? Did you just magically appear in a line of stopped vehicles? Oh, and if you think your only "out" in this scenario is to pull into cross traffic, you need to take/retake an MSF course.
As to the potential wear or strain on the motor due to idling for the duration of the light, I stand by my choice of the word "nebulous"-- vague, indeterminate, imprecise. I don't think there are any statistics that can correlate idling at a long stoplight directly to a shortened engine life, but even if there was a correlation, I'm trading a shorter engine lifespan for a longer Matt lifespan.
Shutting off an engine at only a long stop light is not necessary and is probably harmful. If you were in extended stop and go traffic on a hot summer day, then maybe an occasional shut down and restart is OK, but jeez, the oil cooler will handle stop lights.
I have experience with police Harleys and BMWs both the pre- and post cooling fan eras. We ran in city traffic, long stoplights and all, sometimes idling while on traffic stops, slow riding in parades and funerals, etc, and no one around me had engine damage. If we were to be stationary for a long time we would not run the engine but keep the bike "ON" because it had an extra battery and higher rate charging system. IDK if any bike runs hotter than a Harley in July, and we had temperature gauges on the bikes. Do you know what happens for a couple of minutes after you shut the bike down in hot traffic? The temperature actually rises for a short time before it starts to go down. So you may be actually doing more harm to your engine if you shut it down at lights. And what about those restarts after the oil has drained into the sump? Most engine wear occurs at startups.
You're fron Chicago? I never lived there. Is traffic in my lil' ol' burg in the mountains - admittedly, growing like a weed, and full of college kids...but is it worse here than in the Second City?
How did that knot of twelve get behind me? We were moving in a clot to the light. The knot formed, on Reserve Street, at the freeway cloverleaf and the first signal; and we move as if in a parade all the way to our destinations...which are mostly one of two busy intersections.
So they stopped when I stopped, since the traffic lights somehow manage mostly to drop in my face. So, three minutes at Expressway Blvd, another three minutes at Union Pacific; and then SIX at Moran. And, on a summer afternoon, the mercury in the high nineties.
There is really nothing to do for that engine to prevent catastrophic overheating, other than shut it down at those lights. I love this machine; but one thing the modern water-cooled rides have over it, is their radiators, mostly with fans.
As for the escape route...nice theory they teach. I've never needed it; and to be able to avail, you'd have to be looking in your mirror AT THE EXACT SECOND OF INCIDENT. Which means staring in the mirror. Not watching the traffic or the light.
Now, if I was naked at that stop...the first and only one out...that's another matter. Of course I'd be watching. But the only time that happens out here is between 3am and six.
My Harleys ran MUCH hotter when sitting at stoplights than my CB does, both brands air cooled, and I never had a heat related issue with any Harley motor in the last 25 years while living in Chicago. Honestly, I would have to be sitting in Nevada desert like heat at a stoplight for a really extended time before I would start getting concerned about overheating on the CB. I think this issue is more of a theoretical arguement than a practical concern-I would say to worry less and ride more. The air fins on the CB motor are very well designed and were one of the biggest manufacturing challenges for Honda when deciding to produce our bikes. I think they did a great job.
Yeah. I've never shut off for traffic lights, but temporary construction delays on highways or clearing accidents on bridges etc... anything over 4 or 5 mins and looking to be longer sure.
My fear wouldn't be so much about getting in rear ended, as traffic has long backed up by this point, but losing all my oil flown as soon as I kill the engine. I get that you are also killing the biggest heat generator (combustion itself) but you are also effectively losing all your oil related cooling to the engine's hotspots.
Good point about the oil cooling kmoney. The only time I really ever shut off is when sitting waiting for a freight train to pass. Those can take a while.
Idling versus sitting dead, hot.
The oil contributes to cooling...WHILE MOVING. Stationary and idling, it just gets hotter.
Shutting down, the engine generates no heat. The inner hotter areas radiate to the external surfaces...but that's more an equalization of temperatures than it is, it getting hotter. It's a valid concern but it doesn't seem to me as if the momentarily higher temperatures inside the valve train, are going to be worse than the ever-rising temperatures of a long idle standing still.
If that helps you sleep at night, fine. When shutting down, your oil drains back to the sump. Every engine, at each startup there is a momentary oil starvation and it's an undisputed fact that that is when most engine wear occurs. You may think you're doing right by your engine, but you're not.
BTW- you're only guessing that your engine is entering dangerous temperature territory. Without exact readings in degrees, it's all guessing. Isn't there a warning light on our bikes for entering dangerous temp zone?
EDIT: I've seen in another post that our oil warning light comes ion at 342 F. That does seem high, but the API tests oil at 350deg for 100 solid hours, so, if you are using API approved oil... IOW- I don't know of a traffic signal that stays red for over 100 hours.... :thumbsup:
The oil drains back to the sump, true.
But on a hot engine, just shut down, the lubricated surfaces have a sheen of oil on them. And they are at operating temperatures. And starting up brings oil pressure right back up.
Compare your car, with its oil pressure gauge or light. Starting cold, it takes a moment to build pressure. Restarting after a quick stop, the light goes out almost immediately.
Likewise...you are correct that most engine wear is on starting. COLD starting. Warm starting has virtually no additional wear except to the starter system.
It's not a scientific test, but I have seen this. When I was in my twenties, I drove a cab for a suburban cab company. We used Ford Granadas, with 250 c.i.d. sixes in them.
The company bought them from Hertz, used. They'd have about 50,000 miles on them. We'd run them to about 500,000 miles. And RARELY would the engine let go. The Ford-O-Matic transmissions, yes - but not the engines.
Why not? Because they seldom were left to cool off.
They'd of course get shut down all the time. Stopped on stands. Meal breaks; waiting on fares. But never to cool down...the cabs were run, two 12-hour shifts every day except holidays. Even maintenance was done with them hot...in for an oil change and out 15 minutes later. Guy whose shift it was on would get a break on his lease rate.
All those miles. Even Toyota engines today don't typically go 500,000 miles. Not in typical private-owner use.
Because of the cold shutdowns. Not just any shutdown; but a shutdown to allow complete cooling and draining down of the oil.
Are you 100% certain there's a "sheen"?
What is it's thickness?
And how much of a "sheen" is good enough?
Just like guessing that the engine is getting too hot, you're still guessing.
That's a nice story about the Ford Granadas, but has no bearing on our Honda engines or their expected longevity.
I can tell you an anecdote about Russian tank engines needing replacement after 100 hours, should I expect that from my CB?
You can certainly do as you wish, but I'm making a mental note to not buy any bike you're selling. :P
(I'm also done beating this dead horse). Going to the garage now. :beerchug:
Frictional losses when cold aren't solely due to poor oil circulation, but are related to thermal characteristics. Most pistons are "cam ground" meaning the piston isn't perfectly round (like the cylinder) when cold, but is as close to being perfectly round when the engine has reached it's designed operating temperature. This is why cold engines are designed to idle at a higher rpm when cold, to overcome frictional losses. Cold start-ups are the worse. I believe engines actually get hotter for a short period after shut-down. When stopping after riding for a period of time, I let the engine idle to allow for temperatures to equalize to the greatest extent possible, then if it looks like it's gonna' be awhile (train, construction, accident), I'll shut it off.
Sure.
Because I don't let it overheat.
An air-cooled engine without an integral fan...WILL overheat when stationary. Not "might." WILL. It's why the manual tells you not to start it up and leave it idle when cold. It needs air flowing over the cooling fins and through the oil cooler.
A film of oil is all that's on lubricated parts at any given time. They are lubricated where there is metal-to-metal contact. And of course the contact presses off all but a film of oil.
I have explained how I know that repeated hot starts are not, in general, going to damage an engine. I have not seen or heard any contrary evidence. We KNOW what overheating does, even when not severe enough to seize the engine up. Warped heads, misshaped cylinders resulting in piston slap.
Nowhere, in any manual, warning, shop manual or text, does it advise leaving an engine, any engine, idling as opposed to turning it off. Many makers advise the opposite. Toyota, in some European models, has an engine that shuts of at stoplights and restarts upon releasing the brake pedal.
I grant, should someone buy a bike I've owned for a time, they might want to expect they'll be buying a starter and/or battery. But that's it.
