Shad 37 Top Case/ Honda Rear Carrier
Gingersdaddy_imp Offline
Threads: 19
I installed this top case a few weeks ago and wanted to post some pictures for everyone. The Shad 37 will hold one helmet and a few other items. I can get my helmet and light weight coat in it, but my tourmaster coat with armor will not fit.
Here is the base mounted to the Honda rear carrier.
The mounting holes on the rear carrier did not match the holes in the bracket so I squared it up where I wanted it and drilled though the plastic bracket to match the holes in the carrier. the mounting hardware supplied is not stainless so I'm going the replace the bolts later, make sure you use nylon lock nuts.
The view from the rear. The case locks into the bracket pretty good and tight. The case has a open area right above the opening lever that you can carry the top case around by. I was originally going to go with a black milk create, but just could not do it and spent some money on the case. When it is locked, it is locked to the bracket and the lid is locked. Keep it locked even if its empty or you might come out and find it gone.
I like the CB1100 without anything on it, but need to be able to lock some things up and the Shad Top Case works great for me.
My first time posting pictures, hope they are viewable.
11-17-2013, 05:22 AM
Threads: 698
Likes Given: 789
RE: Shad 37 Top Case/ Honda Rear Carrier
Pictures are fine. Nice looking top case. Much better than a milk crate lol
11-17-2013, 05:27 AM
Threads: 19
(11-17-2013, 05:27 AM)The ferret_imp Wrote: Pictures are fine. Nice looking top case. Much better than a milk crate lol
Thanks Ferret, I like the fact that I can take it off if I'm just joy riding around.
11-17-2013, 05:39 AM
Threads: 698
Likes Given: 789
I have a top case on my ST and on my Majesty. They rarely come off..just so dang handy.
11-17-2013, 05:52 AM
The Spaceman_imp Offline
Threads: 42
I have the Shad 29 and its working great. I picked up mounting points on the small bars that go across the bike, it looks like you got the larger bars that form the frame by drilling. I'll have another look at my installation.
Replacing the hardware with stainless is a great idea; the heads of the original bolts are starting to show a bit of rust.
11-17-2013, 09:20 PM
AzBob_imp Offline
Threads: 6
Looks nice. The thought of being able to take the case off is a good one, but so far, I haven't taken mine off, and don't see myself doing that until I sell the bike (if that day ever comes).
11-21-2013, 07:48 AM
Threads: 19
(11-21-2013, 07:48 AM)AzBob_imp Wrote: Looks nice. The thought of being able to take the case off is a good one, but so far, I haven't taken mine off, and don't see myself doing that until I sell the bike (if that day ever comes).
To be honest, have only taken it off once. I felt it would be nice for over night trips, I could take it in the hotel room like a luggage.Tongue
(11-17-2013, 09:20 PM)The Spaceman_imp Wrote: I have the Shad 29 and its working great. I picked up mounting points on the small bars that go across the bike, it looks like you got the larger bars that form the frame by drilling. I'll have another look at my installation.
My rear carrier has tabs with holes in them, that I used. I was trying not to drill any new holes in the carrier. The Shad cases are pretty nice.Thumbs Up
11-21-2013, 10:25 AM
AzBob_imp Offline
Threads: 6
That's one nice thing about the Givi universal plate, you don't need to drill any holes, no matter what. They engineered a very nice, universal solution that doesn't involve messing with the stock carrier in any way and is still rock solid.
11-22-2013, 07:36 AM
Threads: 19
The shad base plate has multiple holes with square washers for the bolts, but none of the base plate holes lined up with the rear carrier tab holes. just drilled holes in the plastic shad base plate. I didn't look at the Givi top cases, sound like they fit.
11-22-2013, 08:52 AM
AzBob_imp Offline
Threads: 6
The holes in the Givi plate didn't match toward the front, either, but the metal lever, for lack of a better term, that you pass the bolt through can be "attached" to any round tube. So you just find where you want that to run up against the tube of the carrier, and you're done -- nothing to drill. It's hard to explain without pictures.
11-25-2013, 03:29 PM
  SW-Motech Top Case (All CB1100 Models) rdprdp01 2 527 08-20-2025, 06:25 AM
  Top box, Givi, Shad or maybe something else? Davidjill_imp 17 1,401 07-25-2024, 08:22 AM
  Crank Case Cover removal? JF Coastal_imp 47 3,291 08-04-2023, 01:26 PM
  Anyone recommend s a top case for the 13' OEM rear Carrier? iamlegend21087_imp 14 1,182 06-21-2023, 08:51 PM
Last Post: Tbhart89_imp
  Honda top case install Jonnyteabag_imp 11 925 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  Givi SR1118 Top Case Rack active1951_imp 4 505 06-28-2021, 07:08 AM
Last Post: Tom_imp
  Apache 4800 top box. (HF/Pelican case) mvk24_imp 12 1,022 04-16-2021, 04:01 AM
  Givi Side Case Racks...Do they exist? cbolling_imp 21 1,271 08-28-2020, 08:34 PM
  HELP! OEM Top Box/ wrong rear Carrier? 13' CB iamlegend21087_imp 4 515 05-12-2020, 09:16 PM
  Case paint - need a suggestion to match stock skidmarkart_imp 15 860 03-16-2020, 08:20 PM
Last Post: FLYTYM_imp
