CB Eleven-Hundred Thousand Mile Club
This afternoon in Oelrichs, South Dakota, 2013 Honda CB1100D Serial #001742 rolled 100,000 miles and became a member of the CB Eleven-Hundred Thousand Mile Club.
A brief synopsis since riding out of the dealer's shop in September 2013...
Average of 48 mpg for approximately (at least) 2,100 US gallons gasoline consumed. Has burned 85 OCT to 91 OCT both gasohol and non-ethanol fuel with no discernible difference in performance (from this rider).
21 tires replaced and installed, 7 front and 14 rear
23 Oil and filter changes (92 Qts of Honda GN-4 10W-30 motor oil and 23 FRAM 6017A oil filters). Original drain plug gasket still in use, no seeps, weeps or leaks.
Corbin seat installed at 8,000 mi. and Street Shield installed at 25,000 mi. Grab-On foam grips at 1,000 mi. and replaced at 97,000 mi. Otherwise bike is factory stock and set up as from dealer.
Valves checked at 15,000 mi. and all in spec., no adjustment necessary (I intend to have them checked again at 115,000 miles and report values).
Air filter replaced at 47,717 mi.
Rear axle replaced at 64,000 mi. as I stripped the threads when changing a tire (totally my bad).
Chain and sprockets replaced at 54,178 mi. and 91,184 mi.
Fuel Pump (and filter) replaced at 74,788 mi.
Original brake pads (front and rear) also replaced at 74,788 mi.
Original battery replaced at 91,184 mi. The factory original battery was still working fine but I decided that it was "time". It had never been placed on a battery or "trickle" charger.
Original spark plugs still installed (plugs pulled at 64,000 mi. and 2 were regapped and all were reinstalled).
Original brake fluid still installed.
Original everything else (unless I forgot something).
The machine really felt "run in" or "broken-in" at 25,000 mi. when it began to run smoother and produce best power.
After this initial 100,000 mi. test ride I think that I'll keep it. Not a bad machine after all!
I hope that this report provides some useful information.
Later,
Haystack
I am seriously impressed! That's a lot of riding. Kinda wondering "how you did it"!
The other thing that is amazing is your details of the maintenance. Demonstrates a seriously reliable machine. Also very, very impressive. Emphasis once again that the CB1100 is seriously under-appreciated (and under-valued) by the riding community.
You sir, get a gold star!
First, Congratulations on reaching 100k!! That's awesome. 2, thanks for the fascinating info on the longevity of your bike. Hope to get there one day.
Awesome! Congrats. I'd be about at about 60% of your miles had I not traded my first CB for this one. If you stop riding yours now, I can catch you in a measly 7 years, give or take.
Thanks Haystack for the detailed report and congrats on 100K, quite an achievement on any bike and a testament to the build quality and engineering of Honda.Thumbs UpBikerBeer
Thanks for the great report, Haystack!
Ben
Congratulations on a remarkable milestone, Haystack. El Huròn will correct me, but I think you may be only the second forum member to achieve it.
I'm very impressed by the longevity of your brake pads.
Excellent share Haystack. It allows people the opportunity to "bench mark" their maintenance and usage.
Well done but surprised that you still have the original brake /clutch fluid.
Heystack, interesting and worthy report...
As to: "tires replaced and installed, 7 front and 14 rear"... how come 14 rear and 7 front...based on my mileage, my rears last 2-3 longer than fronts, totally opposite..
  850 mile review dorishuntt_imp 1 293 09-22-2024, 11:33 PM
  0 to 60 & Quarter Mile Times KiowaEagle_imp 3 453 06-04-2021, 03:01 AM
  Taiwan cb1100 club cj599_imp 5 497 03-27-2021, 11:14 AM
Last Post: cj599_imp
  Eleven Whole Miles! cookiemech 33 2,419 01-31-2018, 08:29 AM
Last Post: VLJ_imp
  75,000 mile service Haystack_imp 22 1,543 01-07-2018, 02:10 AM
Last Post: ohiorider_imp
  Officially a member of the "OUCH!" club. NateOh_imp 11 803 06-11-2017, 11:19 AM
Last Post: NateOh_imp
  300 mile break in? cb4me?_imp 2 269 05-23-2017, 08:32 AM
  Taiwan CB1100 Club Rally 736cc_imp 1 300 04-08-2017, 10:38 AM
  This Meeting Of The Columbus, OH CB1100 Owners' Club Will Come To Order JackBaruth_imp 10 684 03-23-2016, 11:59 PM
Last Post: JackBaruth_imp
  CB Riders Club Taiwan Motogeezer1949_imp 2 248 02-21-2016, 06:24 AM
