2014 Bread Loaf Seat on 2013 Frame
jlhalsey_imp Offline
Threads: 2
To those of you who have installed the 2014 "bread loaf" seat on 2013 bikes and found that it fits but the grab rails do not run parallel to the new seat, this can be easily corrected. There is a 2014 bracket that bolts to the original grab rail (garnish) rear retaining bracket which provides a second lower fastening point which provides the correct angle for the rail to run parallel to the 2014 seat.
The part numbers are 50168-MGC-N20 right side, 50169-MGC-N20 left side. you will also need two socket head bolts part number 90125-MJG-770 and two nuts 94050-08000.
if you would like to replace the painted grab rails with polished/clear coated rails the part numbers are 84110-MGC-N20 right, 84120-MGC-N20 left $57 ea at Procaliber. The two brackets are about $8 ea.
I will post a picture later today. Its a pretty easy install, even replacing the grab rails which requires unplugging the turn signal wires.
10-19-2014, 01:46 AM
VTR1000F_imp Offline
Threads: 13
RE: 2014 Bread Loaf Seat on 2013 Frame
Interesting!
10-19-2014, 06:51 AM
Likes Given: 789
Cool, good info. Looking forward to the pics.
10-19-2014, 09:23 AM
Ridem32_imp Offline
Threads: 51
Brackets on the 14 deluxe
10-19-2014, 02:52 PM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
10-19-2014, 06:02 PM
Threads: 2
Those are the ones.
10-20-2014, 12:13 AM
pechorin75_imp Offline
Threads: 11
Good info! But am I correct in thinking that this would cause clearance issues for someone who had the '13 Honda luggage rack mounted (since it would tip the whole thing backward/down into the tail light)?
10-20-2014, 01:04 AM
Threads: 2
(10-20-2014, 01:04 AM)pechorin75_imp Wrote: Good info! But am I correct in thinking that this would cause clearance issues for someone who had the '13 Honda luggage rack mounted (since it would tip the whole thing backward/down into the tail light)?
tail light mount is integral to the grab rail so it moves down as well. luggage rack in theory would appear parallel to the seat pan just as the grab rail does.
10-21-2014, 12:04 AM
Ridem32_imp Offline
Threads: 51
Pechorin75: if you mounted rack to bottom hole yes it would drop the rear rack near the taillight at a downward angle! But maybe you could mount the rack in the top hole ( level) then put turn signal mount in bottom hole. I never seen a 13 bike I have 14 deluxe. But that's the only difference I can see on parts digrams is the 13 don't have the bracket!
10-21-2014, 01:17 AM
Headbanger02_imp Offline
Threads: 4
(10-19-2014, 01:46 AM)jlhalsey_imp Wrote: To those of you who have installed the 2014 "bread loaf" seat on 2013 bikes and found that it fits but the grab rails do not run parallel to the new seat, this can be easily corrected. There is a 2014 bracket that bolts to the original grab rail (garnish) rear retaining bracket which provides a second lower fastening point which provides the correct angle for the rail to run parallel to the 2014 seat.
I wonder how hard it would be for me to polish out my own grab handles like the ones on the dlx versus buying them...
05-14-2015, 09:47 AM
  Is the 2014 Deluxe seat a unique size and/or fit? LucienLeFranc 12 678 03-29-2026, 10:31 PM
Last Post: LucienLeFranc
  axle / frame sliders dlm1100_imp 9 951 06-02-2023, 10:41 AM
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,369 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  Frame sliders/engine guards Cqrlm911_imp 81 4,967 11-10-2021, 06:46 AM
  2014 CB1100 EX Seat Fit On 2013 and Older Bikes SUPERCRUZ_imp 36 2,223 06-05-2021, 08:14 AM
  improved seat and 3 cm higher SEAT. the best reform Alfgaxatico_imp 1 312 04-25-2021, 04:47 AM
  Side Cover Question for 2013 and 2014 cbolling_imp 7 587 10-02-2020, 09:34 AM
Last Post: cbolling_imp
  The 2013/2014 Yoshimura Centerstand Bracket Issue Rox_imp 0 252 07-28-2020, 02:40 PM
Last Post: Rox_imp
  Is there a difference between a Corbin Seat for a 2013 standard and a 2014 Deluxe Crazyirv_imp 3 466 06-22-2020, 04:18 PM
  2014 Standard seat johan_imp 16 1,236 06-26-2019, 07:39 PM
