Those who intalled the Arrow slip on
MikeOxbig_imp Offline
Threads: 8
Hi guys, I read some of you applied some type of thermal paste when installing the arrow. I'm hesitant to do that as in my past experience it was really difficult to remove the slip on later on if I decided to change it. Can I use locktite (bue)?
Thanks,
09-03-2015, 03:14 AM
Ack-CB11_imp Offline
Threads: 46
RE: Those who intalled the Arrow slip on
(09-03-2015, 03:14 AM)MikeOxbig_imp Wrote: Hi guys, I read some of you applied some type of thermal paste when installing the arrow. I'm hesitant to do that as in my past experience it was really difficult to remove the slip on later on if I decided to change it. Can I use locktite (bue)?
Thanks,
No, don't use Locktite. Use High temp RTV red silicone. Smear a little on the pipe and let it set overnight after you slip it together. Removal will be a snap, the stuff is real pliable.
See:
[url=http://www.amazon.com/Permatex-81160-High-Temp-Silicone-Gasket/dp/B0002UEN1A/ref=sr_1_1?ie=UTF8&qid=1441312814&sr=8-1]http://www.amazon.com/Permatex-81160-Hig...814&sr=8-1
09-03-2015, 06:41 AM
Threads: 8
Thanks Ack-CB11. My main concern was the removal process later down the road, sounds like this is the right product. I initially was just going to install the Arrow with no paste, has anyone done this? Just wondering if there were any leaks.
09-03-2015, 07:49 AM
JF Coastal_imp Offline
Threads: 23
I don't remember putting any paste on mine. I just slipped it on, and worked great.
09-08-2015, 01:29 AM
Gumby 1100_imp Offline
Threads: 17
How about resistance to discolouring from heat?
I was thinking of putting the Moriwaki Slip-On on my wish list until I learned that the megaphone tends to yellow near the header connection.
Is the Arrow Slip-On any better at keeping its original colour?
09-08-2015, 04:40 AM
INTP_imp Offline
Threads: 10
Mine has not yellowed yet.
09-08-2015, 05:22 AM
Brookland27_imp Offline
Threads: 7
OP use the silicone it works fantastic for sealing the exhaust connection and there is absolutely no issue removing it.
09-08-2015, 11:36 AM
  Exhaust system/slip-on johnny_elpino_imp 26 2,061 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Arrow Slip-On Thoughts le_penseur_imp 84 5,099 05-15-2023, 05:20 AM
Last Post: mrded_imp
  Arrow exhaust. Mixagon_imp 11 896 10-25-2022, 01:56 AM
Last Post: ymtnpoah11_imp
  Arrow full exhaust gretle_2.0 2 342 05-17-2022, 11:38 AM
  delkevik slip on mufflers outback_imp 4 545 10-14-2021, 12:44 AM
Last Post: outback_imp
  loose the arrow jimgl3_imp 33 1,992 08-30-2021, 11:14 PM
  Delkevic Muffler slip-on wgscheib_imp 2 361 06-08-2021, 01:48 AM
  Arrow slip on mufflers DougsZ28_imp 15 1,221 05-13-2021, 04:09 AM
  Intalled DCC 12" Stainless Steel reverse shorty exhaust Garver_imp 10 874 10-13-2020, 03:00 AM
Last Post: Garver_imp
  Arrow full system exhaust tsmetjen_imp 19 1,324 07-29-2020, 03:46 PM
Last Post: tsmetjen_imp
