Frame Sliders vs. Crash Bars
MikeD_imp Offline
Threads: 15
I want to add a little protection to my CB. I know that a lot of you guys have frame sliders installed, and I've seen a that a few have installed crash bars. Which is better? I prefer the looks of the frame sliders, but wonder if the crash bars offer more protection.
09-17-2015, 08:29 AM
ClassicVW_imp Offline
Threads: 6
RE: Frame Sliders vs. Crash Bars
I looked at both and chose crash bars, but I feel you'll be fine with whatever you choose.
09-17-2015, 08:59 AM
Razor Offline
Threads: 32
Likes Received: 58 in 13 posts
Likes Given: 15
(09-17-2015, 08:59 AM)ClassicVW_imp Wrote: I looked at both and chose crash bars, but I feel you'll be fine with whatever you choose.
+1 with George.
Like you; I was initially going with sliders, but changed to the OEM bars. Pick the ones that appeal to you.
09-17-2015, 10:25 AM
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
I got the Over Racing crash bars from Samurider and was more than pleased. After hitting a deer the bike went down on its left side and slid down the road a bit. The only things that touched the pavement were gauge cluster, headlight ring, mirror and clutch lever. The crash bar managed to keep the entire left side of the bike from scraping. Not even the peg or turn signal. Well worth the money! I bought a second set within a few weeks.
09-17-2015, 11:13 AM
CB4ME_imp Offline
Threads: 183
I've "tested" sliders and crash bars on two different bikes. Both types do an excellent job of minimizing damage to the rest of the bike.
09-17-2015, 10:28 PM
Bheezy27403_imp Offline
Threads: 39
I'm guessing there are significant weight savings with the sliders?
09-17-2015, 11:11 PM
Threads: 6
(09-17-2015, 11:11 PM)Bheezy27403_imp Wrote: I'm guessing there are significant weight savings with the sliders?
IDK what "significant savings" would be, but the crash bars must have a smoother aerodynamic profile? Thumbs Up
09-18-2015, 03:51 AM
Threads: 39
Well I'm guessing the bars must be at least 5 lbs?
I took the case savers off my '80 CM400t a million years ago but I seem to remember them being rather heavy. Those pucks can't weigh that much.
09-18-2015, 11:09 AM
Threads: 6
(09-18-2015, 11:09 AM)Bheezy27403_imp Wrote: Well I'm guessing the bars must be at least 5 lbs?
Even so, how will 5 lbs. matter in the overall scheme of things?
09-19-2015, 12:17 AM
furious_blue_imp Offline
Threads: 11
I used sliders on 2 bikes: Speed Triple and CBR250R.
Both were 'tested' in 0 mph tip over incidents and they did a good job keeping things from damage.
I was going to get sliders for the ZX-14, but then I read about a bike that was 'totalled' in a low speed slide because a frame slider bent/broke the frame that it was mounted on.
Because of that, the ZX-14 gets no sliders (and of course there are no crash bars)..
Replacing bodywork is cheaper than a ruined frame (which should NOT be 'straightened' or rewelded IMHO).
For the CB1100 I chose the Honda crashbars.
Some have preferred a bar with more bracing to make the crashbar more rigid, but I tend to regard the crashbar as being like the expanded poly in a helmet: it is MEANT to be crushed in order to save the head.. So I prefer a 'weaker' crashbar that will deform on impacts and thus absorb the shock, rather than a braced crashbar that might transmit more of the shock to the motorcycle..
It doesn't hurt that they look really nice too :-)
09-19-2015, 01:14 AM
  Exhaust Sliders for CB1100EX (World Walk) rdprdp01 2 281 05-13-2026, 05:40 AM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 1 376 04-12-2025, 08:57 AM
Last Post: 17-CB-002
  Fehling crash bars Newceebee_imp 13 1,049 02-03-2025, 11:47 PM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 11 1,093 11-03-2024, 05:24 AM
Last Post: WRXer_imp
  Crash bars question from Biker Dave the Ferret 36 2,621 06-14-2023, 02:35 PM
  axle / frame sliders dlm1100_imp 9 956 06-02-2023, 10:41 AM
  R&G front axle sliders gretle_2.0 11 1,172 06-14-2022, 03:49 AM
  Frame sliders/engine guards Cqrlm911_imp 81 4,988 11-10-2021, 06:46 AM
  Grab bars for pillion Endeavour_imp 1 359 05-15-2021, 08:34 AM
  Crash bars do not fit. olafurarason_imp 3 446 04-22-2021, 12:11 AM
Last Post: olafurarason_imp
