arrow slip on
lynnster_imp Offline
Threads: 2
arrow slip on
I just received my new Arrow slip on and thought I would attempt the installation myself. Forgive the layman's terms here, I'll attempt to describe the problem. I successfully removed the stock muffler (I'm already proud of myself) so onto the install.
Between the new slip on and the base of the exhaust there is a silverish one inch ring of rubber? If I leave the ring on in between the new slip on and the base of the exhaust, the slip on does not match up to the bolt holes. Before I have to call in the guys to help me I wanted to throw this out there to the experts at the CB1100 forum, you guys know it all so I will try to figure this myself with a little help from you"all!
Here's a pic of the slip on with the silverish ring and then the base of the exhaust, I tried forcing the slip on under the silverish ring but that doesnt work, I dont have any experience in this area so learning as I go.
Thanks
Lynn
03-02-2017, 06:47 AM
Likes Received: 633 in 283 posts
Likes Given: 795
RE: arrow slip on
We have several members with arrow slip ons. Surely someone will be along shortly to help.
03-02-2017, 10:05 AM
c-breezy_imp Offline
Threads: 11
arrow slip on
Just looked at mine, had to take a pic from down low since the heat shield covers it:
[Image: d30bda92989b6999f829f9dce1b8d7e2.jpg]
03-02-2017, 10:10 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Received: 200 in 118 posts
Likes Given: 142
RE: arrow slip on
Here is a thread that talks a little about your problem. Maybe reading all 2 pages and looking at the part breakout on page 2 will help. Most of the thread is about what turned out to be improper mounting though.
But you may the the gasket wrong or something.
http://cb1100forum.com/forum/showthread....ight=Arrow
Ok, I just looked in the service manual and for the stock muffler it says,
Install gasket on the exhaust pipe (thats the silver 'rubber' thing)
Install muffler into the exhaust pipe
So, your new Arrow should go into the exhaust pipe. I would imagine some force might be needed to seat it as it is new and never been compressed.
03-02-2017, 10:33 AM
Threads: 2
RE: arrow slip on
(03-02-2017, 10:33 AM)Lord Popgun_imp Wrote: Here is a thread that talks a little about your problem. Maybe reading all 2 pages and looking at the part breakout on page 2 will help. Most of the thread is about what turned out to be improper mounting though.
Thank you so much for the link from other members, I found the problem and the solution from the posts. Just like the other member, I mounted the back part of the slip on to the outside of the screw/bolt on the back part of the bike, so it made the muffler short by about 1/2 inch. I remounted it with the back mount of the slipon on the inside and it now fits.
Wow, you guys are the best!
03-02-2017, 11:11 AM
Lord Popgun Offline
Virginia
Likes Given: 142
RE: arrow slip on
Thumbs Up Glad to be of help!
That thread said something about removing the "DB Killer" too, if you ever want to do that. Big Grin
03-02-2017, 11:18 AM
  Exhaust system/slip-on johnny_elpino_imp 26 2,240 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Arrow Slip-On Thoughts le_penseur_imp 84 5,865 05-15-2023, 05:20 AM
Last Post: mrded_imp
  Arrow exhaust. Mixagon_imp 11 986 10-25-2022, 01:56 AM
Last Post: ymtnpoah11_imp
  Arrow full exhaust gretle_2.0 2 364 05-17-2022, 11:38 AM
  delkevik slip on mufflers outback_imp 4 583 10-14-2021, 12:44 AM
Last Post: outback_imp
  loose the arrow jimgl3_imp 33 2,219 08-30-2021, 11:14 PM
  Delkevic Muffler slip-on wgscheib_imp 2 379 06-08-2021, 01:48 AM
  Arrow slip on mufflers DougsZ28_imp 15 1,308 05-13-2021, 04:09 AM
  Arrow full system exhaust tsmetjen_imp 19 1,498 07-29-2020, 03:46 PM
Last Post: tsmetjen_imp
   Over racing slip on spartanheed_imp 7 805 07-05-2020, 08:33 AM
Last Post: Cobalt23_imp
