ceramic bead seat covers
Houtman_imp Offline
Threads: 115
On very hot days or long trips I used to put a wooden bead cover on my ( Corbin ) seat too prevent "monkey " butt.
A few weeks ago I bought 3 of the ceramic bead covers from Beadrider.
They are really good looking covers and very comfortable plus they give and extra 1/2 inch seat height.
I will probably even leave them on in the winter and just put a sheep skin pad over them as in the colder weather they could be too cold.
All my seats are vinyl and can be sticky in hot weather , the bead cover allows you to move a little.
09-18-2017, 08:52 PM
Likes Given: 83
RE: ceramic bead seat covers
What size did you order and would that be the right size for a stock seat?
09-19-2017, 12:43 AM
Houtman_imp Offline
Threads: 115
I did order the 13 by 13 as the Corbin seat is probably wider than the stock.
As I am 6 ft I do not mind that the bead seat covers a little more than just the seat area, now my thighs stay cooler too !
You might just be ok with the 12 by 12 , check their website.
09-19-2017, 04:18 AM
Likes Given: 83
So...here's a what if'er for you.... Supposing I put a gel pad on the stock seat and the beaded seat on top of that.... Do you think that would give me a little more height or would it just make everything slide around under my butt?
09-19-2017, 07:09 AM
Threads: 347
Likes Received: 843 in 463 posts
Likes Given: 976
I was wondering the same thing.
09-19-2017, 07:17 AM
Likes Received: 582 in 260 posts
Likes Given: 761
Peanut butter and jelly sandwich
09-19-2017, 08:04 AM
Threads: 347
Likes Given: 976
ROFL
09-19-2017, 09:01 AM
Houtman_imp Offline
Threads: 115
(09-19-2017, 07:09 AM)EmptySea_imp Wrote: So...here's a what if'er for you.... Supposing I put a gel pad on the stock seat and the beaded seat on top of that.... Do you think that would give me a little more height or would it just make everything slide around under my butt?
As I do not know your height I think that I would order the ceramic bead seat first , see if this is enough and if not order the gel pad.
09-19-2017, 09:56 AM
  2017 CB1100EX Color matched side covers ceeko_imp 66 4,148 06-25-2023, 10:17 PM
  improved seat and 3 cm higher SEAT. the best reform Alfgaxatico_imp 1 295 04-25-2021, 04:47 AM
  side covers plastic or aluminium? mrded_imp 8 655 10-03-2020, 11:33 AM
  Aftermarket Brake and Clutch Reservoir Covers michael1954 11 922 06-17-2020, 08:42 AM
Last Post: Mtneers
  Side Covers YotaMan_imp 42 2,470 05-16-2020, 08:59 PM
Last Post: Guth_imp
  Yoshimura ceramic coating longevity Buzzard Biker_imp 10 805 01-21-2020, 10:33 PM
  Aluminium side covers for 2014 Houtman_imp 8 589 08-15-2019, 02:00 PM
Last Post: Desert viper_imp
  Installed red side covers on 2013 CB1100 Frulk_imp 15 1,176 10-05-2018, 02:54 PM
  Advice for removing emblems on side covers misterprofessionality 26 1,965 05-01-2018, 07:28 AM
  Dremeled my side covers- what do you think? PowerDubs_imp 71 3,427 02-22-2018, 03:19 AM
