Bolt/Nut Black Plastic Domed Caps
2017EX_imp Offline
Threads: 45
My "Better Half" says I am anal retentive when it comes to my machines and other projects, so I initially hesitated to post my little Mod here. But bolstered by the creativity of others here, decided what the heck, why not. I recently installed SW-Motech case save bars on my bike, and they included black plastic nut/bolt head domed covers. I liked the clean unobtrusive look and initially wanted spares, but could not find them. Then I found them on EBay, listed as "Black Domed Plastic Nut / Bolt Cover Caps", out of China. The material is actually more like a black nylon. It was about $2.50 U.S. for each pack of 10, of each size that was needed, including shipping! They are also available out of the UK on EBay, but more expensive, particularly the shipping. The engine bolts/nuts use "spanner" sizes 17 and 14mm, and are the two sizes needed. I have included before and after pictures of the right side, rear engine hanger bolt/nut heads, plus there is one rear 17mm hanger bolt head on the left side that I capped but did not photograph. They press straight on tightly. To remove grip with a piece of rubber and pull straight off. A very inexpensive, easy, and clean Mod I think. Enjoy.
07-31-2017, 08:28 AM
Likes Received: 617 in 276 posts
Likes Given: 788
RE: Bolt/Nut Black Plastic Domed Caps
Wow, never seen that mod before. Looks pretty good I think.
07-31-2017, 08:33 AM
Likes Given: 1,010
Looks good.
07-31-2017, 08:54 AM
Hondahawkrider_imp Offline
Threads: 14
Looks great, but I'd be interested to how many come off after a few bumps
07-31-2017, 03:10 PM
2017EX_imp Offline
Threads: 45
(07-31-2017, 03:10 PM)Hondahawkrider_imp Wrote: Looks great, but I'd be interested to how many come off after a few bumps
I had considered that, but so far neither the caps supplied with my Motech bars, or the caps I ordered have had any problems. At the minimal cost of $2.50 for a pack of 10 for each size, I figured I would have spares, and no big deal if some failed. The caps actually stretch slightly pressing on, and the fit consequently is tight. The caps are not difficult to remove if necessary, but do take a deliberate, strong grip to pull straight off. Should a cap get loose, a dab of clear silicone adhesive inside the cap would take care of it, but I dont think it would ever be necessary, based on what I have seen so far.
08-01-2017, 06:29 AM
2017EX_imp Offline
Threads: 45
I thought I would post an update on this inexpensive little MOD. After many months of being installed, none of these caps have fallen off or even loosened. As I said in the original post, what got me onto these things was the cover caps supplied for the bolt heads and U clamp nuts for the SW Motech engine guards I installed. I liked the clean unobtrusive look so much that I carried it through to all the front engine bolts and nuts, front down tube bolt heads, and small flange nuts under the rear fender. These things work equally well for standard bolt heads, flange bolt heads, and flange nuts. Press on by hand, remove by gripping with a piece of rubber and pull straight off. One of my pet peeves is exposed thread, typical on the flange nut applications. The caps, aside from the clean finished look, also prevent water, dirt, mud, from collecting in exposed thread. Engine heat has not effected the front engine mount bolts heads or nuts either. The only place I have been able to find them is on EBay, from sellers in China. A package of 10 for each size has averaged $2-$2.50 including shipping. The only thing to be careful of, is to order caps based on wrench ( spanner ) size, i.e., the size wrench or socket that fits the bolt head or nut you are ordering the caps for. To do everything will cost about $6-$7.50 for 30 total caps ( lots of spares @ 10 caps per size ). The Wrench sizes are 17mm, 14mm, and 10mm. If you have SW Motech engine guards, the U bolt nuts take 13mm wrench size. Hope this cheap little mod, if you try it, adds to the enjoyment of your CB1100.
11-22-2017, 02:37 AM
  Brake & clutch res caps Mixagon_imp 6 542 02-13-2021, 03:07 AM
Last Post: The A-man
  side covers plastic or aluminium? mrded_imp 8 706 10-03-2020, 11:33 AM
  Gold Plug Magnetic Oil Drain Bolt 2017EX_imp 15 1,212 03-05-2020, 03:57 AM
Last Post: Teamwalker_imp
  Center Stand Shaft Bolt, Yoshimura RS3 Exhaust HansenCB_imp 8 582 07-28-2018, 08:40 AM
Last Post: HansenCB_imp
  Thread size and pitch of our oil filer caps. kmoney_imp 3 336 01-26-2016, 12:05 PM
Last Post: kmoney_imp
  Bolt Covers? White Dog_imp 7 640 12-19-2015, 01:13 PM
Last Post: 4 Paws_imp
  Plastic all over mjvielle_imp 23 2,469 02-10-2014, 02:31 PM
Last Post: Deanohh_imp
