stock seats compatible between years
pdedse Offline
Threads: 119
Likes Given: 819
Would a stock seat cb1100 from either '13 or '14 fit a '17 ex?
02-04-2018, 06:23 PM
Houtman_imp Offline
Threads: 115
RE: stock seats compatible between years
All my Corbin seats from the 3 years are interchangeable , so I do not see a problem with the stock seats from the different years .
02-04-2018, 11:27 PM
Flytech99_imp Offline
Threads: 4
I've done some research on this subject myself as I plan on fitting a '17 EX seat on my '14 DLX....
From what I've gathered, seats from varying years should be interchangeable as far as mounting. However, due to the varying sizes and relative shape differences at the base of the tank between the '13/'14 Standard, '14 DLX & '17 EX/RS models, there may be slight aesthetic and clearance differences at the front.
That being said, I think the differences would only be noticeable when going between a Standard model OEM seat and DLX/EX bike or vice-versa.
02-06-2018, 09:00 AM
Guth_imp Offline
Threads: 125
I would suggest doing some further searching on this subject as I seem to recall a lot of discussion along these lines when the 2014 DLX first appeared.
02-06-2018, 10:21 AM
peterbaron Offline
Likes Given: 1,014
(02-06-2018, 09:00 AM)Flytech99_imp Wrote: I've done some research on this subject myself as I plan on fitting a '17 EX seat on my '14 DLX....
I think you are correct.
I replaced my 14.6 L tank with 16.8 L/ 2014 white EX tank from Japan/Takaski
At that time, he mentioned about slight interference with my seat and suggested putting a soft cloth in between.
Fitment of 16.8 L tank was so perfect , and I had to do nothing.
Hope this helps to support your findings
pb
02-06-2018, 12:24 PM
PowerDubs_imp Offline
Threads: 125
Peter, is your bike a standard or deluxe?
I was told the new tanks won’t work with the std seat.
02-06-2018, 01:53 PM
Threads: 4
I noticed on Samurider, that Takashi mentions that the limited edition brown RS seat can be retrofitted to previous year DLX and EX models only. Conversely, I see there is a special "EX Style" seat that is only for pre-2017 standard models (probably shaped/sized like the stock standard seat).
Using that info to answer the original poster's question, I would think the '14 DLX seat and '17 RS/EX seats are
a good match for swaps but maybe not so much when putting a standard seat on a 2017....
02-06-2018, 02:10 PM
peterbaron Offline
Likes Given: 1,014
(02-06-2018, 01:53 PM)PowerDubs_imp Wrote: Peter, is your bike a standard or deluxe?
Would say standard = 1 ex. pipe... we never had deluxe in Canada as far as 2013-16 are concerned. First dual ex. pipe was 2017.
My tank is NOT seamless, looks like 2013-16 models...just bigger
More details in this thread:
http://cb1100forum.com/forum/showthread....t=gas+tank
pb
02-06-2018, 09:50 PM
  [SOLVED] Are Hepco & Becker C Bow mounts compatible with the OEM Rear Rack? JRD 14 998 07-09-2026, 07:38 PM
Last Post: JRD
  Stock Mirrors MrBob_imp 5 624 04-11-2025, 03:33 AM
Last Post: balkanhound_imp
  Stock Exhaust Mod SStan11_imp 79 5,819 03-12-2025, 04:32 AM
  Stock Muffler jbird06_imp 8 755 05-02-2024, 11:21 AM
  Honda Seats ↓ milkmaster_imp 9 850 06-15-2023, 12:49 AM
  Mods to OEM seats? 2014ltdltz 7 814 07-05-2022, 05:56 AM
  Racks and model years Classico_imp 14 2,071 07-04-2022, 01:01 AM
Last Post: 1973cb750
  Corbin seats vs. K&H? which one is better misterprofessionality 0 253 05-29-2020, 07:36 AM
  Decat stock pipes ozigoo 4 495 05-22-2020, 10:55 AM
  Stock vs. aftermarket exhaust LongRanger_imp 15 1,180 11-30-2019, 06:30 AM
