Spoke wheels on a 2014 with mags.
FLYTYM_imp Offline
Threads: 82
I just bought a 2014 and the first order of business is to build a nice set of spoke wheels. Will the OEM spoke hubs from any year 2013-2015 bolt up to my 2014 with no modifications? I’m looking at a set of SUN brushed hoops with stainless steel spokes,19 front 17 rear slightly thinner rim up front and the widest rim-tire I can do on the rear.
05-04-2018, 08:09 PM
Likes Given: 1,010
RE: Spoke wheels on a 2014 with mags.
The only OEM spoked wheels were on the 2014 EX model sold in Japan and Europe. It was not imported to the USA. As far as I know the wheels were 18”.
05-04-2018, 09:08 PM
FLYTYM_imp Offline
Threads: 82
(05-04-2018, 09:08 PM)Cormanus_imp Wrote: The only OEM spoked wheels were on the 2014 EX model sold in Japan and Europe. It was not imported to the USA. As far as I know the wheels were 18”.
My question is which spoked hubs are compatible with a 2014?
05-04-2018, 10:42 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Here is a thread by a member who did it. You’ll have to read through it to see if it has the info you need. http://cb1100forum.com/forum/showthread....poke+wheel
05-05-2018, 12:36 AM
FLYTYM_imp Offline
Threads: 82
(05-05-2018, 12:36 AM)Lord Popgun_imp Wrote: Here is a thread by a member who did it. You’ll have to read through it to see if it has the info you need. http://cb1100forum.com/forum/showthread....poke+wheel
Excellent info,thank you very much for the tip. That’s exactly what I’m looking for and as stated it won’t be cheap but with what I have in mind for this bike it will be a very nice build. If anybody’s as old as I am,57 think 750K back in late 70s-early 80s.
05-05-2018, 01:07 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Ha Ha! 57 isn’t old on this board Smile
Check out the poll on this thread. At the top of the thread: http://cb1100forum.com/forum/showthread.php?tid=206
I’ll be 65 in a few weeks and then next year I get to move up a notch on the scale. Woo Hoo, I guess...
05-05-2018, 01:11 AM
Aussieflyer Offline
Threads: 17
Likes Received: 5 in 1 posts
(05-04-2018, 08:09 PM)FLYTYM_imp Wrote: I just bought a 2014 and the first order of business is to build a nice set of spoke wheels. Will the OEM spoke hubs from any year 2013-2015 bolt up to my 2014 with no modifications? I’m looking at a set of SUN brushed hoops with stainless steel spokes,19 front 17 rear slightly thinner rim up front and the widest rim-tire I can do on the rear.
The OEM front hub is straight fit in the forks, axle / brake rotors / spacers all line up perfectly. The OEM rear hub of the spoked wheel has a thinner axle than the mag wheel. I had to make sleeves so that the axle would sit neatly in the swing arm. Also the rear brake caliper carrier is different so the easiest solution is to get one from a 2014 spoked CB1100 (Samurider), and you'll need a longer rear brake hose.
Wonder what tyre choices you will have with a 19" front. Obviously you'll need to consider overall wheel outside diameter so that your new 19" fits inside the fender unless you plan on fabricating a new mounting bracket. Rear end has plenty of room to play with and from what the other members are saying the 160/60 doesn't negatively impact handling, and in a 17" offers plenty of economical tyre choices for every type of riding application.
Good luck with your project, it sounds very interesting.
05-05-2018, 01:56 AM
FLYTYM_imp Offline
Threads: 82
I’ve thought about the front fender clearance with a 19 inch tire,the tire won’t be as tall as the OEM tire so it will be close but if necessary I’ll move the fender a hair. I’m a maintenance mechanic by profession and have access to a mill,lathe so I can make what I need within reason. Thank to all for the info,keep it coming!
05-05-2018, 02:04 AM
  An update on my spoke wheel conversion. FLYTYM_imp 20 1,279 06-17-2023, 02:09 AM
Last Post: FLYTYM_imp
  Adapting to 17" CBR wheels? nsrrider_imp 42 3,024 10-10-2021, 11:34 PM
Last Post: nsrrider_imp
  CB1100EX- Spokes to '14 Alloy Wheels Conversion iamheero_imp 10 905 04-24-2019, 01:26 AM
  Spoke wheel conversion on a 2014 Standard FLYTYM_imp 5 589 03-13-2019, 12:29 PM
  HONDA OEM SPOKED WHEELS for CB1100 CB4ME_imp 21 1,532 11-28-2018, 06:11 PM
  17” wheels...again Foxcroft007_imp 12 897 09-12-2018, 12:35 AM
  JB-Power Magtan JB4 Magnesium wheels lola_imp 37 2,127 07-03-2018, 10:05 PM
  Another question about the spoke wheel conversion. FLYTYM_imp 2 338 05-14-2018, 03:34 PM
  wire spoke wheels jim rosenthal_imp 57 3,219 05-05-2018, 09:18 AM
  Pinstriped my wheels greekcb_imp 16 1,198 04-29-2018, 12:44 PM
Last Post: greekcb_imp
