front fork
sonnyb_imp Offline
Threads: 8
front fork
Would anybody know where I could get that black,upper front fork part(normally it's chrome)or how it is made?
thanks
07-02-2018, 12:44 AM
jtopiso_imp Offline
Threads: 13
RE: front fork
Google for "balinit dlc coating". I think it must be some coating of that kind. I also think it won't be cheap.
07-02-2018, 03:38 AM
sonnyb_imp Offline
Threads: 8
RE: front fork
(07-02-2018, 03:38 AM)jtopiso_imp Wrote: Google for "balinit dlc coating". I think it must be some coating of that kind. I also think it won't be cheap.
I will,
Thanks
07-02-2018, 07:01 AM
jtopiso_imp Offline
Threads: 13
RE: front fork
I will,
Thanks
I will,
Thanks
Let me elaborate on my quick answer (I was posting from the phone, so...)
There are several coatings that could be use. I am sure that there is something among the coatings from "balinit" that would work, but perhaps you have some other supplier closer to your place.
Anyway: the use of chrome for suspension bars and damper rods is due to several propierties, mainly:
-hardness
-corrosion resistance
-friction performance (i.e. low friction coefficient)
So you need something that performs the same or better than a chrome coating but with a black (or very dark) apperance. From the top of my head, DLC would be my first choice, but I'd get profesional advise.
Also: keep in mind that unless you are getting new bars made to your spec, you'll need to strip the chrome first and then apply the new coating. But, by doing so, the OD of the bars has to remain the same. I think this could be quite tricky, as sand blasting the chrome out is not an accurate process, so the final dimension after coating would be difficult to predict.
Or perhaps I am over-thinking about it, and for coating experts this is a piece of cake...
Let's us know if you get a quote.
07-03-2018, 07:50 PM
Threads: 698
Likes Given: 792
RE: front fork
They make " black" chrome don't they? I know several Honda models in the past had black chrome parts, including exhaust.
07-03-2018, 10:50 PM
jtopiso_imp Offline
Threads: 13
RE: front fork
(07-03-2018, 10:50 PM)The ferret_imp Wrote: They make " black" chrome don't they? I know several Honda models in the past had black chrome parts, including exhaust.
Yes, but it's not very common. However, I think it's only a cosmetic /corrosion protective coating, so I don't know if it could be used on suspension bars (in addition to the a surface finish, it requires a high hardness to resist the wear).
07-03-2018, 11:15 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: front fork
Here is a short thing on black chrome plating: https://www.arlingtonplating.com/capabil...e-plating/
07-03-2018, 11:53 PM
sonnyb_imp Offline
Threads: 8
RE: front fork
gentleman,
thank you and keep it coming,I will call Arlington,
07-04-2018, 12:20 AM
jedd_imp Offline
Threads: 27
RE: front fork
Like what others said, the black mirror like look is from DLC coatings ....
https://www.ibccoatings.com/dlc-coating-...eratough-d
you may want to consider DLC (vs, black chrome) because you will see a greater reduction w/ friction over chrome.
This is the main reason for doing DLC on forks.
The motorcross & track junkie guys dlc their fork sliders for around $500 to $600 through suspension shops.
The shops send them off to get it done through an industrial specialty coatings facility they're familiar with.
07-04-2018, 03:50 AM
jtopiso_imp Offline
Threads: 13
RE: front fork
I will,
Thanks
I will,
Thanks
-hardness
It looks like it's a "common" solution: Ti Nitride for some colour options, and DLC (only black) for better performance:
https://www.brooksuspension.co.uk/servic...ating.html
If I had my forks re-coated, I'd choose DLC.
(Color or colour? Undecided ?)
07-04-2018, 06:32 PM
  Front fork seal Guards, not gators peterbaron 30 2,352 02-12-2024, 02:06 AM
  Öhlins front fork Yama_imp 4 446 06-28-2023, 09:43 AM
  ID these fork boots/ fork gaiters Riko_imp 9 861 12-18-2017, 09:43 AM
Last Post: LongRanger_imp
  Fork Boots (Front Gaiters) venturer434_imp 16 1,346 11-04-2016, 09:19 PM
  Interesting option for front fork cartridge kit. kmoney_imp 5 456 12-04-2015, 01:48 PM
Last Post: spacetiger_imp
  Front Fork Boots 1100rider_imp 3 315 03-01-2014, 05:46 AM
Last Post: 1100rider_imp
  Front Fork Brace HondaJon_imp 4 392 08-17-2013, 07:35 PM
Last Post: HondaJon_imp
