Front Fork Brace
HondaJon_imp Offline
Threads: 53
Front Fork Brace
I am looking to get a fork brace in the near future and wanted to get some feedback on the quality of them before I buy. I have found 2, Agras and Kijuma. If you have either, let me know what you think.
Thanks
08-17-2013, 01:00 AM
Jim21680_imp Offline
Threads: 4
RE: Front Fork Brace
I'm glad this came up. Sometimes when I'm riding through slow-speed turns (like in a parking lot or at stop sign corners), I hear the front brakes scrub through the turn. I wonder, could fork flex be causing this? This is the first bike I've ever experienced this with.
It's surprising because I would think our steel front fender would serve as a sufficient brace in itself, whereas my previous bikes have had flimsy plastic fenders. Is there a specific reason you're looking for one?
08-17-2013, 02:13 AM
Threads: 53
Jim
Just seeking some added stability. My last bike had a hydraulic steering stabilizer and I guess I am just used to a very "solid" feel when cornering. I figure the brace should help.
08-17-2013, 06:31 AM
CB4ME_imp Offline
Threads: 183
Here's a picture of an Agras fork stablizer purchased from Samurider. The picture doesn't begin to do it justice. For instance the area of the cross brace that tapers down at each end is done in a series of very fine parellel lines that are simply georgeous. You can't see it in the picture.
This fork brace has very tight tolerances and has to drop straight down between the fork tubes to fit in place. If it's angled just the slightest bit, it will bind.
[Image: 8263da52dad1b091e234a80ca7ec0a4e.jpg]
It's a bit pricey, but I don't think you can go wrong. The Agras is an exquisitely sculptured, precisely manufactuer piece of hardware.
08-17-2013, 09:17 AM
Threads: 53
(08-17-2013, 09:17 AM)CB4ME_imp Wrote: Here's a picture of an Agras fork stablizer purchased from Samurider. The picture doesn't begin to do it justice. For instance the area of the cross brace that tapers down at each end is done in a series of very fine parellel lines that are simply georgeous. You can't see it in the picture.
Sweet. I'm sold. Thanks CB.
08-17-2013, 07:35 PM
  New Fork Brace Uncle Sixer 18 1,893 08-09-2025, 09:52 PM
Last Post: tdbru
  Front fork seal Guards, not gators peterbaron 30 2,283 02-12-2024, 02:06 AM
  Öhlins front fork Yama_imp 4 424 06-28-2023, 09:43 AM
  Fork Brace suhawk305 6 667 06-22-2019, 03:24 AM
Last Post: greekcb_imp
  Fork Brace with protector lip. 17-CB-002 2 379 03-17-2019, 10:14 PM
  front fork sonnyb_imp 14 1,124 07-05-2018, 05:05 PM
Last Post: jtopiso_imp
  ID these fork boots/ fork gaiters Riko_imp 9 820 12-18-2017, 09:43 AM
Last Post: LongRanger_imp
  Fork Boots (Front Gaiters) venturer434_imp 16 1,320 11-04-2016, 09:19 PM
  Interesting option for front fork cartridge kit. kmoney_imp 5 445 12-04-2015, 01:48 PM
Last Post: spacetiger_imp
  Superbrace fork brace darmahman_imp 57 3,536 03-10-2014, 12:11 AM
Last Post: rboe
