Exhaust modification on CB 1100 RS
Saltani_imp Offline
Threads: 3
I’m sure people have noticed that the new CB1100 come with completely sealed (seamless/welded) pipes. Any suggestions on ho to modify the mufflers to make them a little louder??
I looked through the end opening and found an area that could have a hole drilled in. Anyone tried that?
09-18-2018, 05:30 PM
Bheezy27403_imp Offline
Threads: 39
RE: Exhaust modification on CB 1100 RS
Yes. There is a thread around here somewhere where a couple members tried a few things. Use the search feature to find it. Or some other industrious member will add a link here eventually. I'm not sure the results were overwhelming because the main source of sound dampening comes from the cat which is upstream in the system.
09-19-2018, 06:58 AM
Likes Given: 1,010
Not sure anyone’s done anything with the 2017 bike exhausts.
09-19-2018, 09:29 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
I couldn't find anything.
09-19-2018, 09:54 AM
Threads: 39
Ah, didn't know he was asking about the '17's.
09-19-2018, 10:53 AM
itstuantran_imp Offline
Threads: 7
If you look through the tail pipe with a flash light, you will see there are 3 holes with dia approx 6mm each. What you should do is to use a long rod of steel with larger dia, say 8mm, to enlarge those 3 holes, sound will be improved. That what i did.
09-19-2018, 11:32 AM
Likes Given: 1,010
Apologies itstuantran. I forgot you’d modified your RS.
09-19-2018, 12:50 PM
Threads: 7
No problem Cormanus, it's just a little play on my stock exhaust, i've replaced the stock exhaust with full titanium 4-1 system Smile
(09-19-2018, 12:50 PM)Cormanus_imp Wrote: Apologies itstuantran. I forgot you’d modified your RS.
09-19-2018, 01:08 PM
jtopiso_imp Offline
Threads: 13
(09-19-2018, 11:32 AM)itstuantran_imp Wrote: If you look through the tail pipe with a flash light, you will see there are 3 holes with dia approx 6mm each. What you should do is to use a long rod of steel with larger dia, say 8mm, to enlarge those 3 holes, sound will be improved. That what i did.
I think you mean "changed" Tongue
09-19-2018, 05:03 PM
Saltani_imp Offline
Threads: 3
how did you manage that? drill? hammer it through?
09-19-2018, 07:19 PM
  My modification fabrimtb 3 80 Yesterday, 07:56 AM
Last Post: fabrimtb
  Value of Seat Modification clc0000 39 2,694 02-13-2024, 11:02 AM
  A small modification i stole from EmptySea misterprofessionality 21 1,412 04-20-2022, 05:56 AM
  2014 Shift Lever Extension Modification, Replacement? HeavyMetalMech_imp 12 1,056 08-02-2021, 10:29 AM
Last Post: HeavyMetalMech_imp
  hard bag modification Chuckk_imp 30 2,071 03-10-2021, 01:35 AM
  Gear Shifter Modification pekingduck 7 723 11-12-2020, 03:11 PM
  CB 1100 RS front fender modification Ulljanrich_imp 6 519 01-01-2020, 05:38 AM
Last Post: E11even_Hunnit
  Pulsing brake light modification Cqrlm911_imp 11 991 06-08-2019, 12:43 PM
Last Post: LikeAfox_imp
  mount modification for cases? sharkey_imp 2 360 08-23-2016, 05:40 AM
Last Post: sharkey_imp
  REAR SWING ARM MODIFICATION Balkan Banditen_imp 3 349 04-21-2016, 10:41 AM
Last Post: Elipten_imp
