Honda top box from Samurider
motorscooter_imp Offline
Threads: 2
Anybody use OEM Honda top box? Will it fit on Givi rack. How does it mount? I'm thinking I like it. Currently have Givi rear rack mounted.
Thank You, MS
04-08-2019, 02:38 AM
chync_imp Offline
Threads: 20
I have the oem top box. It required an adapter plate to mount on the oem rear rack. So make sure you order the adapter mounting plate as it is it’s own part number. Whether it will mount to the givi rack without modification I have no idea. The adapter was plastic so any mod would likely need to be done to the givi rack.
04-08-2019, 03:27 AM
Threads: 2
RE: Honda top box from Samurider
(04-08-2019, 03:27 AM)chync_imp Wrote: I have the oem top box. It required an adapter plate to mount on the oem rear rack. So make sure you order the adapter mounting plate as it is it’s own part number. Whether it will mount to the givi rack without modification I have no idea. The adapter was plastic so any mod would likely need to be done to the givi rack.
Hey CHYNC: Do the 4 holes on the Honda rack fit the plastic piece you're talking about & what's more do you like the top box? Is your tank red & if so, do the colors match?
04-08-2019, 11:56 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
I have the Honda box, but on a Honda rack.
04-09-2019, 12:27 AM
chync_imp Offline
Threads: 20
The plastic mounting adapter plate is what attaches to the rack and yes the mounting holes match the Honda oem rack. The adapter plate allows the top box to be easily removed using the top box latch without having any other mechanical fasteners.
I bought the black/silver box when I had the stock black gas tank on the bike and I thought it looked fine. I now have a red tank but I have no idea how the red box color looks. I’m guessing it’s close enough since it’s from Honda although it’s hard to get a color to appear the same both in plastic and on metal.
It functions well for what it is. I mostly just use it as a backrest for a passenger.
04-09-2019, 03:44 AM
Hey chync: In terms of the silver component, is it some sort of enamel finish or is it integral with the plastic? That is, if you scuff the silver, will black show through?
04-09-2019, 05:52 PM
chync_imp Offline
Threads: 20
Probably but I have no scratches to tell.
04-09-2019, 09:29 PM
(04-09-2019, 09:29 PM)chync_imp Wrote: Probably but I have no scratches to tell.
Okay, thanks chync.
04-09-2019, 10:20 PM
DBM_imp Offline
Threads: 16
How much?
04-12-2019, 07:39 AM
  Samurider experience? Cormanus 27 2,245 02-13-2026, 08:17 AM
Last Post: suhawk305
  2017 EX Accessories at Samurider CB4ME_imp 7 704 01-29-2026, 05:41 PM
Last Post: JRD
  power port and Samurider Road Comet Fairing 1 tdbru 9 1,001 05-04-2025, 07:20 PM
Last Post: tdbru
  MIZ front fender and tail cowl on Samurider CB4ME_imp 16 1,534 06-27-2022, 12:52 PM
Last Post: CB1100CB_imp
  Samurider Paniers-review + pictures tomas_imp 76 6,288 05-03-2022, 02:35 PM
Last Post: ChiefJP_imp
  More handlebar talk - Samurider Type 2 replacements GrabOn_imp 10 949 07-23-2020, 01:16 AM
Last Post: KiowaEagle_imp
  Samurider is all the Awesomeness! Roper_imp 15 1,100 07-06-2018, 11:47 PM
  Samurider.com experience apex1_imp 5 553 07-05-2018, 10:18 PM
Last Post: Guth_imp
  New Mirrors and Rear Rack from samurider jdinaz_imp 34 2,458 02-04-2018, 01:33 PM
Last Post: treytexag_imp
  Samurider Road Comet Questions 2017EX_imp 10 901 12-12-2017, 03:03 AM
Last Post: 2017EX_imp
