Motech part numbers
Skypilot_imp Offline
Threads: 8
Motech part numbers
I’m swapping my risers for a more upright riding position and have decided on the Motech Barbacks. They have a more rounded look than the GENMARs. Only problem is that despite seeing them in many threads here, the part numbers I’ve found indicate that they DONT fit my 2013.
These are the risers I’m looking for
http://cb1100forum.com/forum/showthread....ght=Risers[/quote]
The part number I have is this from the 2tmoto site but it says 2016 models and up?
P/N: LEH.00.039.21000/B
04-27-2019, 12:10 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
RE: Motech part numbers
That is an interesting question. The part fiche shows the OEM Handlebar holder Lower part number the same for the ‘13 ‘14, and ‘17 standard model. The handlebar part numbers are different. That makes sense as the holes for the control assm pins are different. Diameter is the same.
I used partsfish.com for reference
Since the part numbers are the same for ‘13 and ‘14 and ‘17 I don’t see why they won’t work. Unless they are worried about cable length.
Maybe someone else can shed some light on this.
04-27-2019, 12:49 AM
Ben70_imp Offline
Threads: 23
Hi, Skypilot! I installed Rox 2 inch risers with vibration dampener.. I was after the vibration dampening rather than the riser, so I installed CB500f handlebars to retain approximately the same ergos as stock. At the time, I felt it would have been a stretch (pun intended) to try to use the original bars, so as popgun says, cable length may be an issue
Ben
04-27-2019, 01:14 AM
Threads: 8
Hmm. Any of the forum members that are running these motechs able to chime in? Redbirds and Pdese both have threads that don’t indicate any cable/line length issues.
04-27-2019, 03:32 AM
  SW-Motech Top Case (All CB1100 Models) rdprdp01 2 516 08-20-2025, 06:25 AM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 1 368 04-12-2025, 08:57 AM
Last Post: 17-CB-002
  SW Motech Pro Blaze Honda CB1100 Saddle bags for sale CAN$350 peterbaron 3 454 02-07-2025, 01:01 AM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 11 1,071 11-03-2024, 05:24 AM
Last Post: WRXer_imp
  SW Motech evo racks question 12milesout 6 701 05-07-2024, 06:55 AM
  SW Motech soft panniers Ollie 19 1,562 06-03-2023, 01:52 AM
Last Post: mpuhl_imp
  SW Motech engine guards gretle_2.0 3 455 06-05-2022, 09:54 AM
Last Post: gretle_2.0
  Part No for 2017 EX low seat? p200_imp 17 1,344 05-25-2021, 11:27 AM
Last Post: p200_imp
  Help with SW-Motech Legend Bags rage91_imp 5 565 05-14-2021, 11:34 PM
Last Post: p200_imp
  New SW Motech Pro Engage Tankbag apex1_imp 10 807 12-22-2020, 03:10 AM
Last Post: tod.branko_imp
