Help with SW-Motech Legend Bags
rage91_imp Offline
Threads: 2
Does anyone know if the SW-Motech SLC carriers mount correctly if I have an OEM Honda rack installed?
Thanks!
07-22-2020, 03:13 AM
Redbird_imp Offline
Threads: 7
RE: Help with SW-Motech Legend Bags
I don't know but since you already have the OEM Honda rack installed you can take a look at the installation instructions that are on the Twisted Throttle website https://filestwistedthrottlecom.s3.amazo....10000.pdf and see what you think since you can eyeball your bike with the installed rack. It may be as simple as replacing the supplied mounting bolts with longer ones to account for the rack mounting tabs. Pay attention to any possibility of interfearance with the rack and also consider mounting between the rack attachments and the bike vs mounting outside of the rack attachment points.
07-22-2020, 06:31 AM
Ulljanrich_imp Offline
Threads: 3
Unfortunately that does not work without modification on the SLC Side Carriers.
I have tried it, and it doesnt work plug and play.
As far as my personal research found out, there is not a single solution to combining the SLC Sidecarriers (which are aesthetically the nicest in my view) with a rear carrier.
Also, the original Honda rear carrier is the most stabil takes up to 8kg which is a lot mor then most (or even all) others.
Yet, in winter, I will modify my SLC side carriers, as there is a part on each sid that has to be cut of, made shorter, again welded and have it powder-coated again.
I think, its worth the endeavour, because it will be the best solution for this combination of sides and rear racks.
07-22-2020, 10:16 PM
rage91_imp Offline
Threads: 2
(07-22-2020, 10:16 PM)Ulljanrich_imp Wrote: Unfortunately that does not work without modification on the SLC Side Carriers.
Thanks for the insight, guess it’s back to the drawing board for me to find bags...
07-23-2020, 01:51 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Rage, please take pics when you do that mod. I’m sure there will be interest in how you do the the mod. Thanks.
07-23-2020, 09:20 PM
p200_imp Offline
Threads: 1
Hello Ulljanrich,
Were you able to modify the SLC carriers to work with the Honda rear rack? If you have any pictures or can talk about what you have learned about the mod, I'd really appreciate it.
p
05-14-2021, 11:34 PM
  SW-Motech Top Case (All CB1100 Models) rdprdp01 2 527 08-20-2025, 06:25 AM
  saddle bags for 2014 std ?? tdbru 7 1,116 06-22-2025, 01:03 PM
Last Post: 12milesout
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 1 376 04-12-2025, 08:57 AM
Last Post: 17-CB-002
  Soft Bags to throw on when needed Davidjill_imp 6 621 04-11-2025, 10:50 AM
Last Post: balkanhound_imp
  SW Motech Pro Blaze Honda CB1100 Saddle bags for sale CAN$350 peterbaron 3 461 02-07-2025, 01:01 AM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 11 1,090 11-03-2024, 05:24 AM
Last Post: WRXer_imp
  SW Motech evo racks question 12milesout 6 715 05-07-2024, 06:55 AM
  Side bags soft for 2014 CB1100 omnimj_imp 17 1,459 12-07-2023, 08:51 PM
Last Post: CptMoustache_imp
  SW Motech soft panniers Ollie 19 1,581 06-03-2023, 01:52 AM
Last Post: mpuhl_imp
  SW Motech engine guards gretle_2.0 3 470 06-05-2022, 09:54 AM
Last Post: gretle_2.0
