Led tail light
noisewater_imp Offline
New to the Forum
Threads: 2
Led tail light
Hi guys, just thinking about making a fender eliminator, ive bought some sheet Aluminium and am about to get to work on it. The question i have is regarding the tail light, the particular one i want to use is LED, are there any modifications i need to make to use an LED tail light instead of a standard bulb light? Im handy with most things mechanical but electrical is my downfall. Rolleyes
10-25-2019, 11:32 PM
Stichill Offline
Kentucky, USA
Threads: 93
Likes Received: 9 in 4 posts
Likes Given: 6
RE: Led tail light
For a tail light, I'd say nothing special is required other than correctly wiring it. For turn signals, LED will often cause "hyper flashing" because the current draw causes the flasher module / controller to increase its flashing frequency. So if you are also planning LED turn signals, that will be the problem. The solution is to make sure the turn signals have series resistors to reduce the current draw. Often properly designed LED lamps or modules will include this with the unit.
10-26-2019, 11:04 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
RE: Led tail light
You also need some provision to light the license plate.
10-26-2019, 04:54 PM
RE: Led tail light
Also consider: http://cb1100forum.com/forum/showthread....#pid252416
10-27-2019, 07:49 AM
  MIZ front fender and tail cowl on Samurider CB4ME_imp 16 1,610 06-27-2022, 12:52 PM
Last Post: CB1100CB_imp
  Tail Tidy or short rear Fender (Mudguard) beardyweirdy@me.com_imp 9 954 06-18-2021, 10:07 PM
  License Plate/Tail Light Bracket eddi0_imp 0 253 03-08-2021, 09:42 AM
Last Post: eddi0_imp
  Tail tidy tod.branko_imp 11 1,480 11-07-2020, 04:53 PM
Last Post: run-tmc_imp
  Tail-light Mount eddi0_imp 5 528 08-16-2020, 11:15 AM
  SW-Motech ION 7L-15L Tail Bag TXBikerGuy 8 823 05-18-2020, 11:42 PM
Last Post: Frulk_imp
  Custom fender eliminator & 2017 grab bar with LED strip tail light mod CBhooligan_imp 33 2,846 05-10-2020, 06:24 PM
Last Post: Jfro5687_imp
  2014 Tail loop? Dunn2020_imp 6 593 05-06-2020, 02:17 AM
Last Post: BrandonWeimerskir_imp
  Lockhart Phillips Turn Signals-Lucas Tail Light ChipBeck_imp 43 3,513 04-17-2020, 07:25 AM
Last Post: gman_imp
  tail-bag install Chuckk_imp 6 662 11-19-2019, 05:49 AM
Last Post: IndianRider_imp
