ecu/knee pads
Southwend Offline
Von Zipper
Clarksville Virginia
Threads: 29
Likes Received: 8 in 4 posts
ecu/knee pads
two quick questions for my 2017 EX;
suggestions for knee pads for either side of my gas tank that actually look like they were made for the tank?
where under the seat is the ecu module located?
Thank You--in advance
01-25-2020, 12:08 PM
RE: ecu/knee pads
I used the TechSpec Gripster Tank Grips For Honda CB1100 '13-'17 ...
I utilized only the side tank grips. It is a modern look, and not classy like those on the Triumph Bonneville. However, they worked really well when it mattered.
01-25-2020, 12:15 PM
peterbaron Offline
Likes Given: 996
RE: ecu/knee pads
Rocky has magnetic stick on pads, cut to any dimension???, very sure, he will chime in, after shovelling the snow..lol...
[Image: c07cfdab516803362c76d066c71844e6.jpg]
Rocky's '14 CB
01-25-2020, 12:31 PM
RE: ecu/knee pads
(man that lump is gorgeous)
01-25-2020, 12:38 PM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
RE: ecu/knee pads
Hi southwend, in answer to your query here's where the ecu is mounted under the tank directly above the fuel injectors in a separate plastic sub-frame;
[Image: 1d0dbae194c6255711d2cf243cc96873.jpg]
The ecu can be seen at the lower end of the two foam rubber pieces and is the black plastic unit with the black and the white multi pole connectors and the barcode sticker on it.
As you can see the tank, fuel hose ( with quick connector ), overflow/vent hose and fuelpump wiring has to be removed to gain access to it.
01-25-2020, 02:18 PM
Rocky_imp Offline
Threads: 26
RE: ecu/knee pads
Thanks PB, the snow is finally all shoveled Big Grin Big Grin
A few years ago one of the members posted a pattern for gas tank knee pads which I downloaded and printed. I glued the paper pattern to stiffer cardboard so it would be easier to handle and use.
I ordered two black magnetic sheets from Mag-Knight, traced the pattern, and carefully cut them out. They popped right into place and never move, but are easily removed if needed.
01-25-2020, 07:59 PM
jimgl3_imp Offline
Threads: 27
RE: ecu/knee pads
I never heard of tank grips till I started track days / racing. Do you all decelerate that hard on the street?
01-25-2020, 10:05 PM
RE: ecu/knee pads
(01-25-2020, 10:05 PM)jimgl3_imp Wrote: I never heard of tank grips till I started track days / racing. Do you all decelerate that hard on the street?
The TechSpec Gripster was very useful at freeway speeds against a stiff headwind.
If you happen by chance to experience a dramatic accelerated event, they help too.
01-25-2020, 11:49 PM
Rocky_imp Offline
Threads: 26
RE: ecu/knee pads
I put them on more for a retro look than any real use.
I've since installed fork gaiters - for the look and also tube protection.
01-26-2020, 01:10 AM
2017EX_imp Offline
Threads: 45
RE: ecu/knee pads
Southwind, there are several different ways you can do the tank pads, depending on what you like. I believe the pattern Rocky mentioned is here: http://cb1100forum.com/forum/showthread.php?tid=11249 .
TechSpec precut pads for 2013-2017 CB can be found here: https://techspec-usa.com/products/gripst...grips.html . One of the supposed benefits of the TechSpec is that the adhesive on the back is peel off and re-position/re apply, or peel off/leave off without leaving adhesive residue behind. TechSpec also sells the material un cut, so you can use whatever pattern you like to create your own pads. "Universal" Honda pads are also offered at TechSpec, and no brand universal on EBay.
The last option that comes to mind is to use the pattern Rocky used, or make your own pattern, then take the pattern to an automotive window tint shop. Most of these shops now do "Clear Bra" paint protection film on cars as well. The shop could then use your pattern to cut and apply clear paint protection film to your tank. Sometimes these shops will say they can cut the film to custom fit while it is on the vehicle, but that risks cutting into the paint, depending on the skill of the technician. So, the only way I would do the clear film option is if it is pre cut from a pattern.
01-26-2020, 02:28 AM
  Knee Pads, 2017 EX cookiemech 18 1,287 07-10-2023, 01:24 PM
Last Post: tommymck
  Tech Spec Tank Pads 2017EX_imp 3 396 08-06-2020, 06:10 AM
  NEW L-KNEE peterbaron 86 5,301 06-26-2020, 07:48 AM
  Tank knee pads Greg_imp 46 3,001 07-07-2017, 01:09 AM
Last Post: Retsel_imp
  Arrow slip on and TechSpec tank pads cb4me?_imp 10 834 05-28-2017, 12:54 PM
  Better Brake Pads 736cc_imp 2 314 05-04-2016, 03:47 AM
Last Post: kmoney_imp
  Airhawk Seat pads metalmaven_imp 19 1,530 04-17-2016, 02:15 PM
Last Post: uscgmac_imp
  Moriwaki Skid Pads Retsel_imp 28 2,055 03-07-2016, 10:27 PM
  tank knee pads gcarper_imp 14 1,096 04-26-2015, 05:21 AM
Last Post: gbpack89_imp
  Mag-Knight Magnetic Knee Pads TINK_imp 17 1,237 09-03-2014, 06:28 AM
Last Post: mikedude_imp
