U-Lock - Under the Seat Storage
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Occasionally I park my CB1100 or Bonneville and want more than the steering lock to put me at ease. A disc lock is okay, but my helmet does not use a D-ring strap, and I don't trust those thin wire loops used for that purpose. I needed a U-lock to pass through my helmet's chin bar and around a wheel and maybe around a pole too.
The Honda U-lock that fits under the seat (08M53-MFL-800) would have been okay, but they aren't available in the US, and aren't cheap at more than $125 plus overseas shipping. And they're likely only a mediocre lock.
The Honda CB1100 has a space set aside for their lock under the seat. The ends of the U-loop plug into the two loops at the back by the seat latch, the legs of the loop lie in dedicated channels stamped into the rear fender. The cross-bar portion usually sits in a cavity just ahead of it. The trouble was finding a lock that would fit in those confines. Anything wider or narrower wouldn't fit or clear the seat.
Fortunately, a friend owns a bicycle shop and carries several brands - Kryptonite, ABUS, OnGuard, and several cheaper ones. Only 2 would fit, both from Kryptonite. Their Messenger Mini ($40 or so) has an 11mm diameter shackle. The Messenger Mini has a bent foot on one end of the shackle, so it would not slide into the 2 loops at the rear but still fit in the space fine. You can also get it with an optional loop for more flexibility (Messenger Mini+) as pictured.
The New York Standard was wider, and I had to cut one of the loops (see pics) so it would sort of slide in. It's loop was exactly the right length, but the crossbar piece needed to be stored in the tool compartment. The New York Standard ($80 or so) has a 16mm shackle, and weighs a hefty 4.5 pounds.
I ended up getting both, with the Messenger Mini for my Triumph.
05-02-2020, 09:44 AM
peterbaron Online
Likes Given: 996
RE: U-Lock - Under the Seat Storage
Good find Joe, thanks for sharing Thumbs Up
05-02-2020, 09:50 AM
Guth_imp Offline
Threads: 125
I am trying to envision how all of this works in the actual practice of theft deterrence. Any photos of these locks in use?
05-02-2020, 12:26 PM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
You could also thread it through a disc. It would be hard to thread it through the helmet, wheel, and a pole.
05-02-2020, 03:45 PM
Likes Given: 1,010
Neat. Thanks for that useful information, pekingduck.
05-02-2020, 04:16 PM
Guth_imp Offline
Threads: 125
Ah, got it — thanks.
05-02-2020, 04:38 PM
Cobalt23_imp Offline
Threads: 7
Thanks, I will look into that!
05-04-2020, 12:56 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Of the two, I would recommend the Messenger Mini+ because it is more versatile, lighter, cheaper, and easier to use.
05-04-2020, 02:52 PM
  Honda U Lock guitardo_imp 12 929 04-09-2026, 09:36 AM
  Quad Lock handlebar vs clutch perch and bar-end mirrors Uncle Sixer 1 317 01-04-2026, 01:26 PM
  Phone or Sat Nav? What mount ? Quad lock or...... Davidjill_imp 18 1,381 07-28-2024, 08:49 AM
Last Post: SportsterDoc
   Quad lock stem mount Dunn2020_imp 5 538 06-07-2023, 12:36 AM
  CB1100 Lock Lord Popgun 100 6,783 12-24-2022, 11:15 AM
Last Post: olafurarason_imp
  Installation of a Quad Lock Wireless Charger [No Cut Mod] LayerCake_imp 5 642 06-17-2022, 07:44 AM
Last Post: LayerCake_imp
  U-Lock Rubber Band LakeWylieJoe_imp 39 2,448 05-02-2021, 04:00 AM
Last Post: LakeWylieJoe_imp
  improved seat and 3 cm higher SEAT. the best reform Alfgaxatico_imp 1 310 04-25-2021, 04:47 AM
  QUAD LOCK IPHONE SYSTEM Alfgaxatico_imp 33 1,854 01-25-2021, 08:39 AM
  Incognito/low-profile gear storage? DocRid_imp 11 852 09-25-2017, 09:44 AM
Last Post: iamheero_imp
