Help with fuel tank dimensions
tod.branko_imp Offline
Threads: 19
Guys, I'm currently out of the country and out of reach with my bike, and I found a fuel tank from a 94' CB Seven Fifty, which I would like to swap with my 2014 cb1100 tank. Now, I would like to ask if anyone has nothing better to do or has a stock tank laying around, could take a picture of the bottom and measure the spaces between the front anchors and the rear bolt hole.
Also if you have any idea as to why this swap won't work, I'm listening.
And for rationale, because I know people will ask - I want a bigger tank, with flush tank cap, and I don't want to pay the price of the EX/RS tank. I also want to do a custom color so I'd rather do it on a spare tank that re-do the stock tank.
Any help is very appreciated
'14 CB1100 STD 5 speed
03-21-2021, 12:31 AM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
RE: Help with fuel tank dimensions
Tod here's a link to some pictures of the frame, i " guesured " the dimension from outside the rubber mounts to be around 180 mm but someone else may have a better measurement for that.
http://cb1100forum.com/forum/showthread....=fuel+tank
I hope your new tank will fit around those frame members.
Just a reminder that the fueltank also has a fuel level, fuelpump with connections for overflow and breather hose.
03-21-2021, 01:19 AM
The A-man Offline
Western North Carolina
Threads: 9
Likes Received: 79 in 30 posts
Likes Given: 50
Tod - try this picture. This is my spare 2014 DLX tank. Note, I have the yardstick "0.00" inch lined up with the centerline of the attachment hole, and I have the yardstick propped up so that it's in plan with the two front capture features (where the rubber snubbers mount). Optically, it doesn't look like it's lined up with the mounting hole, but it is. Hopefully, you can do some rough scaling from this.
[Image: 64b56fb3702bb21a4c536c5261bc3401.jpg]
03-21-2021, 01:52 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
Tod, the 750 used a single narrow backbone on the frame, which allowed a large fuel area. The CB1100 tank is shallow to allow the multi-tube frame. Also, remember the fuel pump opening is large, and the 750 had only a small petcock.
03-21-2021, 02:19 AM
Threads: 19
Thank you very much everyone for your input, that's exactly why I reached out. I will co sider all these things before I make a decision. Thank you so much
03-21-2021, 03:52 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Its seems to me that the tank would extensive modification to work on our bike.
03-21-2021, 04:03 AM
  Fuel tank protection. olafurarason_imp 4 585 04-11-2023, 08:20 AM
Last Post: curated_imp
  bigger fuel tank Guaza14_imp 12 997 08-03-2020, 12:11 AM
  Whitehouse tank and fuel indication / range tommymck 7 734 07-01-2018, 05:38 PM
  Need larger capacity fuel tank! J-Bob_imp 13 967 04-21-2018, 05:01 PM
Last Post: Nicki-nitro_imp
  Rear Suspension Dimensions Aussieflyer 4 516 12-07-2017, 12:25 PM
Last Post: Aussieflyer
  CB1100 Standard Fuel tank and Side Covers iwannaride_imp 2 291 03-08-2017, 10:45 AM
Last Post: flynrider
  Removed tank stickers, installed clear tank protector ryanschillinger_imp 6 628 07-01-2016, 12:09 AM
Last Post: Guth_imp
  Replacing Fuel Tank nymets1585_imp 12 915 11-04-2015, 06:50 PM
Last Post: bambo838_imp
  4.7 gal K-10 fuel tank CB4ME_imp 16 1,193 03-02-2015, 12:01 AM
  Blue fuel tank? frontrange_kg_imp 15 798 02-22-2014, 07:19 AM
Last Post: Elipten_imp
