tanks & saddles
Looking at the CB1100/s on wikipedia, it seems that the earli(er) models had significantly different tanks (and saddles). Has anybody experienced both configurations (may be changed his bike) ? I'd like to know whether there is more to it than just looks ?
Another question, if anybody has changed to the newer configuration, and the old tank and saddle is still sitting in his garage ... I might be interested in buying them.
Always safe rides !
Welcome to the forum j3gq.
As far as I am concerned there were only 2 different CB1100/OEM tank's shapes;
2010-2016 and 2017 & up (seamless) with some narrow variety of tank capacity, depending on the local regulations, from 14.6L to 16.8 L, if not mistaken. These should fit between models, however fuel pumps come with 3 or 4 pin connectors, so check yours.
Similar with the seats, DLX had a taller?? seat and if used on other models may??? slightly interfere with some garnish.
You can use forum's search engine to get all the info you need.
Maybe some others will chime in to comment...or/and correct me, especially with the seats.
You may also check forum's for sale section or https://www.samurider.com/?cat=269
(10-08-2020, 07:18 AM)j3gq_imp Wrote: Looking at the CB1100/s on wikipedia, it seems that the earli(er) models had significantly different tanks (and saddles). Has anybody experienced both configurations (may be changed his bike) ? I'd like to know whether there is more to it than just looks ?
Always safe rides !
I have a black 2014 Standard tank if you are interested. PM me....
  tanks and seats j3gq_imp 2 297 10-08-2020, 03:31 PM
  Petrol Tanks seam dented. To fix or not to fix? zirconxi_imp 4 492 10-06-2020, 12:20 AM
  Plastic Fuel Tanks postoak_imp 11 751 08-17-2017, 09:11 AM
Last Post: Desert viper_imp
  larger tanks on the '14s. Olyrider 1 233 05-12-2015, 05:52 AM
  Waaaaaa! There's a chip in my tanks paint! TINK_imp 21 1,306 03-13-2015, 01:50 AM
Last Post: Rebel73_imp
   sending my seat to Baldwin Motorbike Saddles canyonwlf7_imp 3 367 02-23-2015, 10:10 PM
Last Post: canyonwlf7_imp
