Plastic Fuel Tanks
There's a question on one of those sites where you can ask about anything: "Why have bike manufacturers shifted to plastic fuel tanks?"
Everybody starts answering the question, but I wonder if the assumption is correct. Are most bikes made today coming with plastic fuel tanks?
some are but they are not doing well with Ethanol gas. Ducatis in particular have had issues with it with tanks swwelling.
Would you say a majority of bike models have plastic or metal tanks?
Also what is a "seamless" tank like the new CB1100EX has?
Earlier Moto Guzzi V7Rs had plastic tanks and had issues. My 2009 HD XR1200 has a plastic tank and no issues so far. Im sure there's no stats on this but I'd be curious to see if black tanks in hot climates had more issues than those of other colors in cooler climates. I can't help but think, ethanol not withstanding that this plays an issue.
I believe they're roto-molded nylon, not plastic, but it's best to avoid bikes with these things unless they're buried underneath other bodywork, for the reason Ferret identified. Moto Guzzi and Ducati both had significant issues with swollen tanks and had to issue worldwide recalls or honor warranty claims to replace them. Guzzi no longer uses them on the V7 line.
(Sorry Frulk, we were both typing at the same time).
So is the EX tank nylon (which is a form of plastic) or metal?
Someone will pipe up, but I believe they're metal (the '13's and '14's are metal). I've not seen a '17 in the flesh yet.
So how are they seamless? Are they actually seamless or the seam just doesn't show?
Frulk :Black absorb the sunlight.....
And i guess erhanol expand more as normal gas with by heat...
New CB has a metal tank and I would suppose that the tank is formed by some hydraulic process and what seams are welded are then ground smooth. I also note that the new CB has a tank filler ring that would easily adapt to a tank bag ring and eliminate the need for a magnetic bag and tank scratches that may happen with same.
  tanks & saddles j3gq_imp 2 346 10-09-2020, 01:41 AM
Last Post: Mtneers
  tanks and seats j3gq_imp 2 284 10-08-2020, 03:31 PM
  Petrol Tanks seam dented. To fix or not to fix? zirconxi_imp 4 470 10-06-2020, 12:20 AM
  plastic cover gear indicator pdedse 6 544 10-10-2016, 06:18 PM
Last Post: Riko_imp
  Plastic Bananas Noleshot_imp 0 160 06-20-2016, 10:24 PM
Last Post: Noleshot_imp
  larger tanks on the '14s. Olyrider 1 229 05-12-2015, 05:52 AM
  Waaaaaa! There's a chip in my tanks paint! TINK_imp 21 1,239 03-13-2015, 01:50 AM
Last Post: Rebel73_imp
  Replacing plastic parts Buffalohead_imp 20 1,279 08-07-2013, 03:53 AM
Last Post: wildezt_imp
