Preload setting's affect on stock seat comfortability
Playing with different preload setting, i found that my CB1100 2013 stock seat is most comfortable when the bike's preload are set with the bottom tube of the cradle frame parallel with the road.. Previously, I set the rear slightly higher, and the stock seat kind of putting stress on my lower thigh and I thought the CB stock seats are uncomfortable and contour are weird, until recently I raise the front preload and reduce the rear, so that the bottom tube is parallel to the road. And no more stressed lower thigh. I had always considering adding a gel pad to the seat. Now it seems unnecessary. So if you are like me and felt the thigh are stressed riding on stock CB seat, can try to adjust the bike posture with the bottom frame tube parallel to the road. It seems the contour of the stock seat are design with this posture in mind. Just some personal experience.
Good info. I cannot get comfortable on my 2017. I took the rubbers out of the foot pegs and that helped. Then, I put on some adjustable pegs, which helped a lot, but I could not match them to the foot controls, so I took them off pretty quickly. Next, I plan to have my seat modified to be taller. Any suggestions on the best source for seat mods?
I switched to a K&H Hi seat which helped a lot, more than I thought it would.
(10-29-2020, 03:45 AM)Clayfoot_imp Wrote: Good info. I cannot get comfortable on my 2017. I took the rubbers out of the foot pegs and that helped. Then, I put on some adjustable pegs, which helped a lot, but I could not match them to the foot controls, so I took them off pretty quickly. Next, I plan to have my seat modified to be taller. Any suggestions on the best source for seat mods?
I raised my seat by acquiring a Honda Africa Twin.
I miss the CB, but the seat upgrade was worth it. Smile
  Stock handle bar specs mvk24_imp 6 602 07-06-2023, 09:22 AM
  Setting clock for daylight savings time the Ferret 44 4,345 03-13-2022, 11:46 AM
  14 CB1100 stock exhaust (cat) Feelergaugephil_imp 21 1,686 10-10-2019, 01:41 PM
Last Post: Feelergaugephil_imp
  A question about stock OEM Bridgestones ohiorider_imp 28 2,027 08-31-2018, 09:05 AM
Last Post: Bigskyorbust_imp
  All stock vs modified jodytek_imp 22 1,303 12-02-2017, 03:20 AM
Last Post: SportsterDoc
  Stock Exhaust COCB1100_imp 23 1,380 07-02-2017, 10:32 AM
Last Post: Avalanchegsx_imp
  stock side covers easyriderhatch_imp 8 580 02-08-2017, 12:17 PM
Last Post: letsjet_imp
  Stock mirrors and the DGR MikeD_imp 1 268 09-26-2016, 10:29 AM
  Differences between stock seats, Std vs. Dlx dsinned_imp 4 430 07-14-2016, 10:19 AM
Last Post: Elipten_imp
  2013 STD seat vs. 2014 DLX seat VTR1000F_imp 24 1,825 07-06-2016, 10:51 AM
Last Post: Offroad
