Second oil change in the books
After this last trip it was time to change the oil. I just went and serviced the whole bike as I showed in the How to do your own 600 mile service thread.
Only this time I let it drain for a couple hours while I cleaned the interior of my Civic. Also this time I held back 6 oz from the gallon so I didn't overfill it. Last time I put in an even gallon and the oil covered the site window. Wanted to avoid that this time. When all was said and done I added 2 of those ounces back in to bring it even with the top line. I will recheck after the first ride. So it looks like 4 oz short of a gallon fills mine with filter change.
Throttle play was still good at 4 mm. Neither crankcase pressure drain tubes had any fluid in them. I did adjust the chain the tiniest bit, maybe 1/8" which I probably could have skipped. There are no tight spots I could find. All lights are still functioning properly.
I did notice my front tire was beginning to exhibit some slight cupping on each side of center. I checked pressure before the trip..36 lbs, and when I checked it today, also 36 pounds. I added 2 pounds to the front to bring it to 38 pounds. Will see if that helps. Back still measured 42, same as before the trip, and looked fine other than a slight flattening in the center which is to be expected.
Ready for another 4,000 miles now, at which time the rear tire will probably be toast, and maybe the front as well if the cupping continues.
Great report ferret. I'm jealous of all the miles you've been able to put on her. I need more time to ride! Angry
Which weight oil did you use :-)
I grabbed he wrong jug yesterday when I picked it up and got 10w40 instead of 10w30. No biggie. Not much difference between the two, and the temp ranges they are good for overlap. I run enough miles that the lighter weight will be back in there before fall.
Mr. Ferret, I am a weird man with OCD who keeps the ear close to the engine every now and then to check for sounds all the time. do you feel the engine is running quieter with the heavier oil..? I am currently on 10w30..
(08-01-2013, 06:54 AM)wildezt_imp Wrote: Mr. Ferret, I am a weird man with OCD who keeps the ear close to the engine every now and then to check for sounds all the time. do you feel the engine is running quieter with the heavier oil..? I am currently on 10w30..
Nope
Thanks..!
get a length of heater hose and hold one end up to your ear and the other end up to the engine in various places, like a doctor and stethoscope. You'll hear sounds you've never heard before.
so am not the only one...its an epidemic.. Big Grin
  tire change Tom_imp 7 656 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,087 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 766 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 3,505 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 718 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,133 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 914 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 350 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 1,985 11-28-2017, 09:24 AM
Last Post: SportsterDoc
  Completed second oil change (DIY) venturer434_imp 5 426 05-11-2017, 07:47 PM
Last Post: Rocky_imp
