Turn Signals Not Working (sort of)
I swapped out the factory rear turn signals for the smaller version that Honda uses on their Japanese bikes. However the running lights don't work, only the blinkers. When I plugged the original rear signals back in I get the same symptom - no lights except blinking lights when the turn signal switch is activated.
Any ideas?
I believe there are no "running lights" on the rears, only the fronts. Most any street bike I have owned (and many have been Hondas) are this way. The lights only come on and blink when being used to signal a turn.
I've seen that many of the European countries do not run front turn signal running lights like we have here in the US.
Did you open the front lenses of the signals to see if those bulbs are even dual filament?
(10-15-2013, 10:45 AM)thumper_imp Wrote: I've seen that many of the European countries do not run front turn signal running lights like we have here in the US.
the front running lights /blinkers are not dual filament. Rears are blinker only....same bulbs.
CB4ME, it sounds like your rear signals are working correctly. U.S. DOT standards only allow amber running lights on the front of a vehicle. The rear lights should be dark unless signalling a turn.
Thanks everyone!! Thanks
A big doh moment!! Blush Blush Blush
I'd never paid attention to the rear signal operation.
BTW, the install was a breeze and they really look good. The best part is the wiring involved......NONE. (as long as you remember the lights only come on it blinking mode) Blush Blush Blush
There's a kit for Harleys that lets the rear turn signals act as running lights the way the fronts do. One of the vendors ought to produce one for our bikes.
(10-15-2013, 10:06 PM)The Spaceman_imp Wrote: There's a kit for Harleys that lets the rear turn signals act as running lights the way the fronts do. One of the vendors ought to produce one for our bikes.
Unless the rear turn signals are red, that could get you a ticket in some states. In AZ, ARS 28-931 says in part :
C. All lighting devices and reflectors mounted on the rear of any vehicle shall display or reflect a red color, except that:
1. The stoplight or other signal device may be red, amber or yellow, except on a commercial vehicle, as defined in section 28-2231, the stoplight shall be red and the other signal devices shall be red or amber.
Since this follows the U.S. DOT standards (which applies to manufacturers), most states have similar laws to keep vehicle owners from straying too far from the standard.
While following a friend on his Harley last week, I noticed that he had an interesting mod. Whenever he applied the brakes, both the brake light and the two rear amber turn signals came on. If he happened to be signalling for a turn when applying the brakes, then the non-blinking amber light would come on solid with the brake light. It was pretty effective and quite noticeable.
Technically, since his rear ambers come on as a "signal device", that would seem to be legal in our state.
This is one of many kits:
http://www.highgearhobbies.com/estore-v3...l-kit.html
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 2,841 03-06-2026, 04:31 AM
  Clutch Not Working Henrik_imp 7 636 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 559 12-08-2022, 09:24 PM
Last Post: leung_imp
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 753 05-01-2022, 06:23 AM
  New Speedometer Not Working wanobiben_imp 15 1,148 04-13-2022, 01:38 AM
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,263 03-31-2022, 04:03 AM
  Changing Placement of Rear Turn Signals eddi0_imp 9 754 06-27-2021, 03:57 AM
Last Post: Gordo_imp
  Indicators not working AlexCB_imp 8 619 02-28-2021, 03:22 AM
  Speedometer and Odometer aren't working caleb_dud_imp 13 1,033 01-07-2021, 02:59 AM
Last Post: Gover_imp
  LED turn signals Jeff in OH_imp 18 1,246 11-15-2020, 07:11 AM
Last Post: FLYTYM_imp
