Alt/rectifier output
If someone with a shop manual could look up the output it would be appreciated.
Just got off the phone with Honda and they say 11amp output from the alternator. That would be 132 watts which seems real low for any bike.
Thanks
More i think about it he had to be giving me the reserve, a 55 watt bulb would eat up almost half the output. I know the St1100 has 28amp alts and most guys put in 40amp upgrades.
At 5,000 rpm the alternator should put out enough power to be able to read greater than 15 volts at the battery. That's all the Shop Manual says on that subject.
(10-30-2013, 07:32 AM)meowguy_imp Wrote: At 5,000 rpm the alternator should put out enough power to be able to read greater than 15 volts at the battery. That's all the Shop Manual says on that subject.
Thanks M,
yes 14.6 volts is your 12volt charging sweet spot
I was hoping it would show amps or watts.
From the M.O.M. it says for specifications.
Generator output: .336 KW/5,000 rpm. Does that help.
Thanks M & Stretch,
When I called the dealer they had to contact Honda and they still got it wrong. This is why i never bring my bike in for service. LMAO
It's 336 watts. That's 28 amps@12V. Either info or calculations are in error.
You should probably use 14.6v for your calculation which yields 23 amps. Take out the 7-8 amps operating current and that still leaves plenty of amps for accessories.
Meowguy,
Shop Manual page 1-8 lists the specs. Says 0.336KW at 5000RPM
Oddly I found that in the owners manual. I never thought to check the Specs in the shop manual.
Posted from my iPhone using [url=http://tapatalk.com/m?id=1]Tapatalk.
  speed sensor output Lord Popgun 16 1,070 10-09-2020, 09:20 AM
  Battery not Charging - High output Alternator? beardyweirdy@me.com_imp 12 856 01-03-2017, 08:30 AM
Last Post: AzBob_imp
  Electrical Output? kenfyoozed_imp 50 2,913 12-13-2013, 01:15 AM
Last Post: gcarper_imp
