S100 safe on tires and disk brakes?
Just wanted to know if S100 is safe on tires and disk brakes? Could not really tell from their website if it is.
Yes, spray on with bike cold, not in direct sunlight, rinse right away, direct hard spray, finish rinsing with a shower type spray. Dry with soft cloth or blower. After dry take for 10 mile "drying ride" applying brakes often and being careful with tires for the first 5 miles.
Thanks. I will give it a try.
I just bought some of this today. From what I hear it's pretty good stuff.
Honda actually sells this product as Hondabrite I have read.
IMHO, S100 leaves surfaces stripped too "dry" and open to corrosion. It's ok for a few things, but I like something with a bit of wax in it for the final finish on most areas of the bike.
[quote='meowguy' pid='14442' dateline='1379709790']
Why would you put that on disc brakes? I just clean mine with rubbing alcohol. BTW I put some on my headlamp and it made the surface on the smooth plastic feel like sand paper, I immediately cleaned it of, maybe the heat from the lamp had some weird reaction?
Mr Jangles it gets on the discs when you spray the bike, but it won't hurt them. S100 specifies bike being cold when sprayed and out of direct sunlight. maybe that is why you had issues? I have been using S100 and sister product Bike Brite on my motorcycles for maybe 15 years with no issues. It's good stuff. Will be using it later today to clean the dirt from yesterdays rain ride off the CB.
I've been using S100 since the early 90's - only problems I've had was when I didn't rinse enough, and got a white filmy look.
(07-20-2014, 04:26 PM)Mr Jangles_imp Wrote: [quote='meowguy' pid='14442' dateline='1379709790']
I was mistaken in my previous post, I was using the S100 plastic polish for my face shield, of course you would not use that on disc brakes. I now see that the stuff your using is a cleaner...I stand corrected.
  Front Brakes ain't what they used to be misterprofessionality 11 1,389 05-09-2025, 09:10 PM
Last Post: Whoops
  Bleeding brakes with ABS j3gq_imp 31 2,228 12-22-2021, 08:31 AM
  Small quiz; brakes are dragging. max 31 2,392 11-29-2021, 12:20 PM
  2014 CB 1100 Front Brakes troubleshooting mustang462002_imp 23 3,176 11-17-2021, 06:53 AM
Last Post: max
  Bleeding brakes (CB1100A non-ABS) tod.branko_imp 5 567 09-20-2021, 07:43 AM
  2014 CB1100 Deluxe No front brakes Roger the shrubber_imp 16 1,069 08-05-2021, 02:01 AM
  brakes simulating T.Rex j3gq_imp 8 805 10-12-2020, 02:49 AM
  Rear brakes... what I did wrong and where to go now? Inhouse Bob 32 2,392 07-11-2020, 01:37 AM
  Linked Brakes Cormanus 11 1,277 12-11-2019, 08:10 PM
Last Post: jtopiso_imp
  Brakes! Captainwoot_imp 19 1,440 08-22-2019, 08:51 AM
Last Post: Captainwoot_imp
