Transmission Noisier After Oil Change
The trans area sounds like it has added a new high pitched squeaky rattle little extra sound after the first oil change after about 600 miles.
This is after warm up.
This sound is not present on cold start up.
I took it to Honda and they don't hear it but I do .
The service dept. guy says it is due to the 10W30 Honda oil being of a lower viscosity than the original break-in oil from the factory.
Time will tell.
Any other owner have a similar experience?
Welcome to the forum, slowgroove. You started an oil thread on your first post. Nice.
To my knowledge, they don't use break in oil from the factory. It's supposed to be changed at 600 miles during the break in period, but it's 10w30. My bike came new with 10w30 oil.
I put in 10w30 dino oil at the 600 mile service then switched to 10w40 dino at 2000 miles. With the 10w40, I always felt like the transmission was louder and didn't quite feel right. At 4000 miles I switched to 10w30 semi synthetic - made a subtle but nice improvement - transmission is quieter and shifting is smoother - especially downshifting to first. Don't think it's my imagination, but my bike likes 10w30 better than 10w40.
I'd adjust the crankshaft balancer and see if that helps.
Did you do anything else to the bike like add a windshield or some other accessory? These things can change what you hear.
Also, is the oil level correct?
Lets hear what you hear, post a video from your smartphone.
(09-30-2014, 08:05 AM)Pauley_imp Wrote: Welcome to the forum, slowgroove. You started an oil thread on your first post. Nice.
The sound is only noticeable at idle speeds. Thanks for your input.
(09-30-2014, 09:25 AM)ClassicVW_imp Wrote: Did you do anything else to the bike like add a windshield or some other accessory? These things can change what you hear.
I did not make any other changes. The sound is mostly noticeable at idle .
(09-30-2014, 09:54 AM)CIP57_imp Wrote: Lets hear what you hear, post a video from your smartphone.
Sorry I don't even have a cellphone. Thanks for the idea.
(09-30-2014, 08:05 AM)dlhmatt_imp Wrote: I'd adjust the crankshaft balancer and see if that helps.
I am not qualified, and don't know what to do.
Did you change the oil yourself or did you bring it in for service??
(09-30-2014, 10:05 AM)CIP57_imp Wrote: Did you change the oil yourself or did you bring it in for service??
I changed the oil myself.
We really need to hear the noise to have some idea of your problem. Many members have had lower end knock after the first oil change, mostly due to a heavier weight oil. Did you change the filter and use a OEM filter???
I am not qualified, and don't know what to do. I found your one beer adjust method. Thank you.
(09-30-2014, 10:14 AM)CIP57_imp Wrote: We really need to hear the noise to have some idea of your problem. Many members have had lower end knock after the first oil change, mostly due to a heavier weight oil. Did you change the filter and use a OEM filter???
I used Honda 10W30 and a Fram filter for the first oil change.
After I bought a new Honda oil filter from the dealer today I have changed the oil a second time . This second oil change is with the OEM Honda oil filter and once again Honda 10W30 oil.
Too cold for a ride today to see it there is a difference.
Too cold for a ride today to see it there is a difference. I viewed and heard the video with the low end knock. No I do not have a sound like that poor guy has.
Too cold for a ride today to see it there is a difference. I viewed and heard the video with the low end knock. No I do not have a sound like that poor guy has. I only put about 70 miles on the oil change with the Fram lilter.
  tire change Tom_imp 7 660 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,106 02-20-2021, 02:42 PM
  Transmission power routing and speeds LakeWylieJoe_imp 6 583 01-10-2021, 10:30 AM
Last Post: jimgl3_imp
  Oil Change interest? Scotty_imp 10 780 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 3,563 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 731 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,147 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 917 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 357 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 2,002 11-28-2017, 09:24 AM
Last Post: SportsterDoc
