Threads: 8
Since I had it serviced last week whenever I take her on a run there is a strong smell of petrol (or is it exhaust fumes?) that smells out the garage. I noticed a couple of drops of oil that leaked from one of those two hoses that hang out below the engine, but only a couple of drops - nothing major. Is that related? Can't see any other leaks.
Has anyone had this problem? I wondered if the mechanic has forgotton the screw something back on??
Likes Given: 141
What service was performed? That could help to narrow it down.
Other than that, you are not overfilling the tank are you?
Threads: 8
Sorted. Jumped to wrong conclusion about the service. It was a hose between I guess the petrol tank and the engine which was "stretched", I.e. leaking. Luckily I discovered this just prior to a big 12 day trip, which I'm now happily on.
Likes Given: 141
Yes, there is not much slack in the tank to fuel connection line. You can only lift the tank a small amount to get your hand in there to remove the fuel line.
Glad you sorted it out before there was a fire.
