First oil change question
My "new" 2013 CB has 380 miles.
It sat on the dealer's floor for 2 years and has the factory oil in it.
I am headed for a 600 mile trip in two days. The oil in the sight glass looks clear.
Should I change my oil in anticipation of passing 600 miles this week, realizing that the oil has been in the bike for 2 years? Or should I just change it when I return home a little over 600 miles.
I appreciate any thoughts and advice.
Thank you
Headed to the white mountains.
George
Leave it there. Change it on return. The oil hasn't "gone off" in two years.
At the risk of starting another oil thread I would recommend, when the time comes, that you replace the oil with Dr Dactyl's Hubris Omni Grade Motorcycle Oil (the Only Oil for the Gentleman Motorcyclist). Unfortunately it is not possible for you as the U.S. Dept of Justice has just embargoed this product.
An oil thread! I love these! Smile I won't use Dr. Dactyl's Hubris Omni Grade Motorcycle Oil since I read about it's not 100% synthetic and contains mostly hubris. Plus I'm not a gentleman.
ROFL
Now, this is a specific question about a one-time event in the hopefully long life of me and my bike.
No thread. No thread
900 miles on the break in oil shouldn't be a problem. Two suggestions:
1. Make sure there is oil in the bike and that you can see it in the sight glass.
2. If you are concerned why don't you plan to ride by a Honda dealer, or any certified motorcycle shop, at about the 600 mile mark. Give or take 50 - 100 miles. Call ahead and arrange a time for a filter and oil change. 30 minutes later you should be on your way. The remainder of the service can await you return home.
Cheers and enjoy those White Mountains
Your bike will be fine either way but personally I would change it out. The oil is probably still good for lubrication but it's also likely full of metal shavings from the engine breaking in over the first 380 miles. I did the first oil change on my bike at 200 miles and noticed the engine running a good bit smoother afterwards. Couldn't hurt to do it before a long ride. Smile
Novice and geosar, not wishing to cast aspersions, but be grateful that, for the time being at least, the U.S. Department of Justice has banned the import of Dr Dactyl's Hubris Omnigrade Motor Oil. [url=http://cb1100forum.com/forum/showthread.php?tid=5796]This post tells of the aftermath of my experience with putting it in the engine.
While I don't know if the Hubris Oil had anything to do with the fact that my bike is now immobile, my mechanic did call me yesterday to say he thought it had more in common with the waste from a commercial deep fryer than automotive oil. He said he'd get back to me when he'd tried cooking some fries in it.
(05-12-2015, 07:08 PM)Cormanus_imp Wrote: Novice and geosar, not wishing to cast aspersions, but be grateful that, for the time being at least, the U.S. Department of Justice has banned the import of Dr Dactyl's Hubris Omnigrade Motor Oil. [url=http://cb1100forum.com/forum/showthread.php?tid=5796]This post tells of the aftermath of my experience with putting it in the engine.
ROFL Maybe you can use it for Diesel fuel.
(05-12-2015, 02:06 PM)JPX_imp Wrote: Your bike will be fine either way but personally I would change it out. The oil is probably still good for lubrication but it's also likely full of metal shavings from the engine breaking in over the first 380 miles. I did the first oil change on my bike at 200 miles and noticed the engine running a good bit smoother afterwards. Couldn't hurt to do it before a long ride. Smile
Good idea I think. You'll have more peace of mind while on the road and that's worth a lot.
I changed the oil and filter.
Thank you for the advice. And I got to buy more things-another filter wrench and a measuring funnel.
Thanks again to Ferret for the "How To" section on the 600 mile tune up and his packing tutorial. Ready for tomorrow.
George
  tire change Tom_imp 7 664 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 4,262 02-20-2021, 02:42 PM
  Oil Change interest? Scotty_imp 10 806 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 3,710 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 770 02-09-2019, 05:08 AM
  600 Mile Oil Change - First timer with question + pics LordWasr_imp 7 543 05-03-2018, 10:12 AM
Last Post: Magnus_imp
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,187 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 920 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 368 03-12-2018, 08:46 PM
Last Post: Wisedrum
  First oil change SportsterDoc 30 2,069 11-28-2017, 09:24 AM
Last Post: SportsterDoc
