Resetting tripmeter and fuel mileage meter
I've had this 2014 Std several months now and every time I refuel, I face this same problem. Tonight, I finally figured out that if I hold the A button on the A miles ridden, all the meters are zero-balanced. DUH! What I have been doing is using the A button to move to the B miles ridden and holding the A button down, which zero-balances the B meters but not the A. So, now I know (but can no longer prove it) my average MPH for almost 2K miles is/was 48.9. I'll have to start all over to see accumulative MPH in the future, as well as miles per trip.
Hi, on my standard 2013, i use button a for day miles and button b for each fueling i zero it and divide mile by quantity fueled... last tank i average 60 mpg. It use to be between 50-55mpg. Tested last tank by not going over 4000 rpm to get that result. Button a or b, i zero it by holding it 4-5 seconds.
Envoyé de mon SGH-T889V en utilisant Tapatalk
Are there buttons?
(08-04-2015, 11:57 AM)valkanut_imp Wrote: Hi, on my standard 2013, i use button a for day miles and button b for each fueling i zero it and divide mile by quantity fueled... last tank i average 60 mpg. It use to be between 50-55mpg. Tested last tank by not going over 4000 rpm to get that result. Button a or b, i zero it by holding it 4-5 seconds.
There must be a difference between the 2013 and 2014. Pushing the B button does nothing, unless held down with the A button to change the time.
  New speed meter replacement ACE_IRA_imp 3 518 02-13-2025, 06:25 AM
  Gas Mileage? Gingersdaddy_imp 210 14,663 08-07-2023, 08:03 AM
  High mileage and oil consumption Jurlie_imp 24 2,077 04-07-2023, 06:05 AM
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,215 03-31-2022, 04:03 AM
  Nasty Decel Pop poor gas mileage adogsnyder99_imp 18 1,323 06-30-2021, 07:17 AM
  Tire Mileage Billie_imp 25 2,314 03-13-2021, 04:18 AM
Last Post: Scotty_imp
  Replacement Meter Back Cover jpeppers_imp 25 1,738 10-15-2020, 10:52 PM
  The actual required services by mileage Streetshark07_imp 5 458 06-29-2019, 07:58 AM
Last Post: SportsterDoc
  Resetting Tripometer eric1son_imp 10 584 08-21-2018, 09:06 PM
  Tire mileage Ghost_diver_imp 23 1,287 06-13-2015, 02:08 AM
Last Post: Wisedrum
