What are some (uncommon) maintenance tips that not many people know about?
Please share your tips for keeping the cb1100 running smoothly to cleanings tips. Thumbs Up
All responses are appreciated.
In a way, not so uncommon, but here I presents my tips.
After a ride, I mostly, or even a day after, clean the bike from the spurs it
gained during the trip. Some dust, mud or insects.
This takes less time, than let the dirt take over and then do a
very long cleaning session.
For this purpose I use different mediums to clean it, from water with some dishes
cleaner in it, to Pronto, a furniture polish, yes, or some other polish, over to chrome polish.
Simply everything can be involved , which I have at hand.
My maintenance routine, besides oil change, is more often oiling the chain, keep a
right amount of air in the wheels, have enough gasoline in the tank and that's it.
Off it goes. For kilometers and kilometers. The CB is very frugal...
Wisedrum
Stick to the maintenance schedule, no short cuts. That's hardly an uncommon tip. But here is one - check the bike carefully for corrosion, particularly areas such as the triple tree clamps and where the oil lines join the cooler. Even if no corrosion exists, after cleaning, spray a little anti-corrosion agent anywhere that might present a problem. I find ACF 50 most effacious in every way.
Lube the clutch pivot pin
http://www.cb1100forum.com/forum/showthr...p?tid=6755
Make sure your bars and levers are adjusted to fit you
http://www.cb1100forum.com/forum/showthr...p?tid=3636
Everyone should learn how to change their own oil and filter and perform basic safety checks incl checking chain tension and checking tire pressure
also there are 2 capped overflow hoses that need to be drained occasionally one under left foot peg and one under FI bodies
also learn where your fuses are and brake fluid reservoirs
http://www.cb1100forum.com/forum/showthread.php?tid=202
Adjust your headlight beam for most effectiveness
http://www.cb1100forum.com/forum/showthread.php?tid=905
Make sure your battery bolts are clean and tight
http://www.cb1100forum.com/forum/showthr...p?tid=4886
Check your air cleaner and either clean or replace
http://www.cb1100forum.com/forum/showthr...p?tid=1676
know how to replace your headlight bulb
http://www.cb1100forum.com/forum/showthread.php?tid=595
Learn how to set up your suspension properly
http://www.cb1100forum.com/forum/showthr...p?tid=2902
brake and clutch fluid. To me that's totally common & obviously necessary, but for some reason almost everyone I know with a bike has brown, dirty fluid. I can never understand that.
There is one tute in the How To Section on bleeding the brakes on a 2013 ABS
http://cb1100forum.com/forum/showthread.php?tid=6727
And one ( no pics unfortunately) on bleeding the clutch
http://cb1100forum.com/forum/showthread.php?tid=4655
I have one very firm belief on something that takes a huge toll on many, many vehicles/motorcycles.
Getting on it, and revving it out is just fine, but wait until the motor is up to operating temperature before doing it. I see people getting off work, and simply giving whatever vehicle they're in 100% wot as soon as they hit the highway that is less than a 100 yards from the parking lot.
I run stuff hard, and frequent the drag-strip at least a dozen times a year, and will not go wot until whatever I'm driving is "up to operating temp". I realize that is sort of vague on an air cooled motorcycle that has no temp guage, but giver her 5 minutes or maybe 2-3 miles before laying into her. I'm 40 years old, and have been hot-rodding everything I've owned with a motor since I was 5, and have never had an engine failure, and this pet peave, among clean/fresh fluids and a good tune-up are what I believe gives me outrageously great results of dependability.
(09-04-2015, 01:15 PM)jeffskar_imp Wrote: I have one very firm belief on something that takes a huge toll on many, many vehicles/motorcycles.
Yeah. I see this a lot too and it makes me cringe. One cool feature I remember from the older BMW M cars was the redline on the tach would start out low and increase to normal as the car warmed up. I get it was probably needed in those engines due to their design, but this would be a cool reminder feature to put on more everyday cars.
I always use a high-pressure air hose to blow out the brake dust from the brake calipers and off the brake rotors. While I'm at it I give the whole bike a quick going-over with the air hose; simple, quick, and effective.
(09-04-2015, 11:56 PM)Dave_imp Wrote: I always use a high-pressure air hose to blow out the brake dust from the brake calipers and off the brake rotors. While I'm at it I give the whole bike a quick going-over with the air hose; simple, quick, and effective.
That's a top tip Dave and I might add using the high pressure air to dry and clean the chain after using chain cleaner, then apply your favorite chain lube.
  Advice please--maintenance on new to me CB LucienLeFranc 11 825 06-24-2026, 01:34 PM
  Basic Maintenance: Daily Check rdprdp01 17 1,421 03-01-2025, 02:52 AM
  New members tips max 54 4,567 10-29-2023, 12:11 AM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,258 10-18-2022, 01:55 AM
  Interesting Maintenance YouTube Channel tommymck 4 434 09-10-2022, 03:14 AM
Last Post: alprider
  brake maintenance advice needed misterprofessionality 5 451 12-08-2021, 06:57 AM
  Some valve adjustment tips and tricks. LakeWylieJoe_imp 58 5,577 01-18-2021, 02:06 AM
Last Post: bflint
  Paint maintenance Cormanus 17 1,300 04-13-2020, 01:19 PM
  Handy Cheat Sheet for Maintenance and Wheel removal on my 2017 17-CB-002 12 870 04-17-2019, 12:40 AM
Last Post: ArbitraryThawt_imp
  Engine break out tips and tricks ACE_IRA_imp 7 528 01-29-2019, 12:30 PM
