Brake pads down after 8000 km
Hi there,
I was washing my CB and, as always, looked in every corner to see any problem.
My front brake pads are very very thin and just after 8000km !!
I called my mechanic who was so surprised he asked me to show him the motorcycle.
Indeed the pads are used a lot.
It is even more shocking because at the 6000km service he said the pads were already 50% used.
Does anyone had a similar problem ?
I hear a light and uneven sound when I ride, has anyone the same light sound ?
I plan to go on a road trip next week, hope to find and fix the problem before that !
I changed front and rear pads at 14,000 km. The second set (Brembo sinter) seems to last longer.
I did a search and found one member got about the same mileage you did and some with mileage like Django. And you did say you use the brakes a lot. They are wear items and if you ride hard, well are going to wear them out Smile At least they are pretty cheap.
I have just under 19,000 miles on mine. Plan on changing them out at next oil change or when I get tires whichever comes first.
I put new rear pads on my bike when I purchased it around 7,000 miles (11,265 km). I am now at 20,000 miles (32,186 km) and it looks like I need to replace both front and rear soon.
(03-12-2016, 03:43 AM)Paul_imp Wrote: Hi there,
I hear this from my front brakes. Not sure which rotor it's coming from, but it's like the pad lightly rubs the rotor once a rotation. I would assume it's a slightly warped rotor? I have no pulsing when braking so I haven't really worried about it. I only hear the noise when going slow through something like a parking lot when the sound reflects off parked cars. It's very quiet though.
I do ride a lot in Paris and so use the brakes every 10 meters. But 8000Km still is quite fast! Particularly when I look at your answers.
Olekzap, thanks I feel less alone Smile I am going to change the pads this Saturday and I asked the mechanic to look closely if he sees any problem with the brakes system.
I keep you posted
Has much to do with where you ride as how. When I lived in Jacksonville and commuted daily in traffic, I was lucky to get 20K miles out of pads on my P/U. Brake pads on bikes wore out fast also.
Living in very rural south Georgia now it's not unusual to get 100K miles on pads for a P/U and 20K or better on the bike. My Nissan P/U has 92K now and the pads still look good for another 10K.
  Brake Pads... Simplified Yata-Garasu_imp 20 1,714 03-02-2025, 08:28 PM
  Any one use Ceramic Brake pads? mvk24_imp 6 613 05-14-2022, 12:53 AM
Last Post: bvictory_imp
  brake pads which is best? modmaster_imp 32 2,124 08-27-2021, 10:21 AM
Last Post: jimgl3_imp
  Suggested brake pads? mvk24_imp 12 874 03-21-2021, 04:05 AM
  Rear brake rotor and new pads Sandhog_imp 13 861 01-08-2021, 04:51 AM
Last Post: ethan.phan613_imp
  Correct part number for front brake pads Frulk_imp 7 561 02-18-2020, 08:06 AM
Last Post: iamheero_imp
  Replaced front brake pads for 1st time at 20K miles Frulk_imp 15 937 01-04-2020, 02:15 AM
Last Post: Bheezy27403_imp
  I looked and I looked... brake pads simplest2remember_imp 3 337 07-01-2019, 08:27 AM
Last Post: itsme67_imp
  How to change front brake pads 2013 abs ? 562loosenoodle_imp 20 1,117 02-04-2019, 01:47 PM
  for non-ABS riders: which Brake pads are you all using? misterprofessionality 10 672 12-31-2018, 10:15 PM
Last Post: chync_imp
