 Completed First Oil Change (DIY)
Finally completed the first oil change myself.
- Oil Filter came off easily with the std oil wrench.
- No major issues overall, checked the chain , throttle play.. everything was fine.
- Installed new Honda OEM oil filter ( Hand tight only)
- Replenished it with Honda recommended oil.( Was careful not to overfill by watching the oil sight glass window)
- After draining out all the used oil from the bike , I dropped off the oil to a recycling depot. Noticed very fine shiny material on the bottom of Blitz oil collector. I use this oil collector to drain the oil on my 2001 Triumph Bonneville as well and have never cleaned it after emptying all the used oil. This time I decided clean this to watch for any shiny deposits during my next oil change..
- Feels great and my weekend has already started..
Congrats. It's an easy job on this bike compared to many others.
(11-03-2016, 09:00 AM)venturer434_imp Wrote: Finally completed the first oil change myself.
This is why I cut the oil filters open at least for a few changes just to be sure nothing looks like it is starting to fail.
Bice!
I am going to do the same soon, now just 350 km Big Grin
That "shiny stuff" is normal for the first couple of oil changes. Sometimes, there's a silver sheen on top of the oil (looking at the drain pan).
Don't freak out - it's supposed to be like that.
Oh yeah - and congratulations on your 1st oil change !
Congrats! Doing routine maintenance on your own bike really improves the ownership experience.
On my Ural the engine and transmission plugs are magnetic and it s routine to see swarf whenever you perform service, 2500km is the recommended interval. Chunks showing up are a cause for concern though. Russian vs Japanese engineering and manufacturing - both earned their reputation.
Yep. Changed mine not too long ago. The oil was still pretty clean tho but went ahead and changed anyway.
memphismike! How're you doing? Haven't seen you for a bit.
About to my first oil change on my "used" 2013, (1,600 miles) and notice a screw in the middle of the oil level window. What is the screw for?
Also, can't see to oil level line, I suspect/hope its over-filled.
The filler opening has a knurled plug, is this standard? Looks hard to grab hold of.
The little screw is connectd to a wiper on the inside of the window. When you turn it, it wipes the window.
The knurled plug is most likely a replacement made by one of our members and sold to a bunch of us. The original is a plastic plug that with a 'blade' I guess you call it that you grab.
The oil is pretty clear, or light honey colored and is probably over the upper limit line. When you drain it, you will see what is going on.
Look here at Ferret's How To and you can see it all, plug and everything. http://cb1100forum.com/forum/showthread.php?tid=202
  tire change Tom_imp 7 754 05-31-2021, 11:37 PM
Last Post: Tom_imp
  First oil change for this heathen koehlerk_imp 67 5,065 02-20-2021, 02:42 PM
   Ticking / clicking sound after oil change simplest2remember_imp 12 994 02-03-2021, 01:32 AM
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 704 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  Oil Change interest? Scotty_imp 10 956 09-15-2020, 09:40 PM
  Oil Change Time! Jambo_imp 57 4,268 09-06-2020, 08:40 AM
Last Post: Jambo_imp
  Oil change before/after winter? HikerToo_imp 11 878 02-09-2019, 05:08 AM
  Oil Filter Change: Every oil change or every other? dbarkdoll_imp 22 1,351 04-17-2018, 12:46 AM
Last Post: Knave_imp
  Oil change questions... ride4now_imp 16 1,112 04-12-2018, 02:12 PM
  fork oil change Houtman_imp 4 432 03-12-2018, 08:46 PM
Last Post: Wisedrum
