Threads: 15
Hey guys,
I'm coming up on 12k miles on my 14. I've noticed that after a gear change (Particularly the lower gears) there's a little bit of a lag in the power. I'll release the clutch and twist the throttle and the power first lags, then surges. I've checked my chain. What else would you suggests?
Thanks
Likes Received: 589 in 263 posts
Likes Given: 767
Try Seafoam first, you may have some dirty gas or injectors.
Next check outside spark plugs for condition. They should be clean with tan ceramics. (inside plugs should be same as outside plugs so check outside first. If they look good don't check inside plugs. I changed mine at 25K but it wasn't necessary.
Threads: 129
I think stale/dirty gas is a plausible explanation. Considering the miles on your bike, does it tend to sit unused for lengthy periods? If so, regular treatment of the fuel with Seafoam or Stabil may be something to consider for the future.
Threads: 15
(06-29-2017, 02:27 AM)The ferret_imp Wrote: Try Seafoam first, you may have some dirty gas or injectors.
I've never used sea foam on a bike. Where all do you add it? Just the tank?
Sent from my VS987 using Tapatalk
Likes Given: 767
Yes..gas tank. For a 3.7 gallon tank add about 6 or 7 oz to a full tank. If you only have a partial tank in it just add 3 1/2 or 4 oz and then ride it for at least 10 or 20 miles to run it into the system.
Threads: 15
(06-29-2017, 03:48 AM)The ferret_imp Wrote: Yes..gas tank. For a 3.7 gallon tank add about 6 or 7 oz to a full tank. If you only have a partial tank in it just add 3 1/2 or 4 oz and then ride it for at least 10 or 20 miles to run it into the system.
Any hoses or anything?
Threads: 20
The delay you are experiencing sounds similar but more dramatic than the effect you can get when the engine runs lean from the stock setup. I added a power commander and had my air/fuel ratios re-mapped on a dyno and it eliminated the throttle lag. But mine was simply the lag from the lean settings from the factory not any restrictions in the fuel lines.
Likes Given: 767
(06-29-2017, 03:54 AM)Jaychaynes_imp Wrote: (06-29-2017, 03:48 AM)The ferret_imp Wrote: Yes..gas tank. For a 3.7 gallon tank add about 6 or 7 oz to a full tank. If you only have a partial tank in it just add 3 1/2 or 4 oz and then ride it for at least 10 or 20 miles to run it into the system.
Don't understand the question
Threads: 15
(06-29-2017, 06:15 AM)The ferret_imp Wrote: (06-29-2017, 03:54 AM)Jaychaynes_imp Wrote: (06-29-2017, 03:48 AM)The ferret_imp Wrote: Yes..gas tank. For a 3.7 gallon tank add about 6 or 7 oz to a full tank. If you only have a partial tank in it just add 3 1/2 or 4 oz and then ride it for at least 10 or 20 miles to run it into the system.
Don't understand the question The vacuum hose under the tank.
